Page 1 of 1
[SOLVED] Importing large packages onto the WAPT server
Published: November 27, 2025 - 4:48 PM
by erems
I often have trouble importing large WAPT packages (for example, the 7GB Windows11-upgrade) into our private repository. I frequently get error messages.
I was wondering if there wasn't a better way to import these packages, perhaps by downloading the package from the store and then transferring it directly to our server?
In any case, if you have any tips, I'd appreciate it.
Thanks.
PS: Sometimes, even after the error message, the package appears in the repository. Generally, I delete it just to be safe. When this happens, is there a way to verify that the package is indeed legitimate (without having to install it)?
Re: Importing large packages onto the WAPT server
Published: November 28, 2025 - 10:21
by blemoigne
Here is the documentation: https://www.wapt.fr/fr/doc/wapt-faq-pac ... repository
Have a good day,
Bertrand
Published: Dec 1, 2025 - 5:09 PM
by erems
Yes, thank you, we'll try that.
