Page 1 of 1
Reporting station with the following dependency
Published: Dec 3, 2025 - 08:08
by PA DEQUIDT
I managed to build the report below so that it returns all the packages that depend on the package PACK-XXX :
SELECT DISTINCT
    p.package
FROM
    packages p,
    unnest(p.depends) AS dep
WHERE
    dep ILIKE '%%PAQUET-XXX%%';
However, I am unable to build the reporting so that for a PACKET-YYY the reporting returns all the machines on which the package has been added as a dependency.
If you have any ideas for the construction, I'm all ears.
Thank you so much.
Pierre-Alexis DEQUIDT
Re: Reporting position with dependency
Published: Dec 8, 2025 - 3:21 PM
by Jarnaud
Can you try this query?
SELECT DISTINCT
    h.computer_name AS hostname
FROM
    hosts h
JOIN
    hostpackagesstatus hp ON h.uuid = hp.host_id
WHERE
    'PAQUET-YYY' = ANY(hp.depends);
Does this answer your question?
Yours sincerely
