Page 1 of 1
Alternating between primary and secondary customer deposits.
Published: February 11, 2026 - 08:13
by cedric_974
I'm going to reuse part of one of my posts to avoid rewriting everything. :D
I'm connecting to a corporate console on a remote primary repository (WAN) which is using HTTPS, which I'll call Principal01.fr.
Principal01.fr has the IP address 192.1.1.3.
A GPO on a Windows domain deployed the WAPT agent on the machines with the following settings in wapt-get.ini:
repo_url=//Principal01.fr/wapt
wapt_server=https:/Principal01.fr
I then set up a secondary repository (LAN) using HTTP, which I'll call Secondary02.fr, and which seems to be working correctly: it synchronizes properly with Principal01.fr.
Secondary02.fr has the IP address 192.168.1.3.
I added a rule based on clients' IP addresses:
If the client belongs to the 192.168.1.0/24 network, then the repository used should be http://Secondaire02.fr/wapt
. I checked WAPT, WUA, and WADS and disabled fallback.
This is where things get complicated. Randomly, on my console (on Principal01.fr), when I go to the Inventory section and select a client from the 192.168.1.0/24 range, in the Repositories tab, I sometimes see the primary repository and sometimes the secondary repository. I can't find an explanation for why sometimes my clients stop connecting to the secondary repository.
Thank you for your help.
