Page 1 of 1
[RESOLVED] Secondary repositories -> 403 Client Error: Forbidden
Published: March 5, 2026 - 2:07 PM
by yoni
WAPT Enterprise Server 2.6.1.1765.
We are experiencing an issue with our secondary repositories, which are no longer functioning. They are deployed on Windows 11 systems. Installed package: tis-remote-repo-http version 2.6.1.1765.
client log waptservice.log: [waptcore WaptTaskManager 13204] INFO Repo packages index http://s50dn-depot.fr/Packages is not available: 403 Client Error: Forbidden for url: http://s50dn-depot.fr/Packages
wapt console log: Exception: THttpClientSocket.WGet: HEAD s50dn-depot.fr:80/wapt/ipt-mail_1.1-25_windows_10.0_DEV.wapt failed as 403 Forbidden
However, from the client machine, the command "curl http://s50dn-depot.fr/wapt/ipt-mail_1.1 ... 0_DEV.wapt " correctly returns a status code 200.
Could you tell me what to check on the secondary repository?
Thank you for your help.
Yoni
Re: Secondary repositories -> 403 Client Error: Forbidden
Published: March 5, 2026 - 3:59 PM
by sfonteneau
The `/wapt` rule is missing from the secondary repository rule.
`http://s50dn-depot.fr/Packages`
should become:
`http://s50dn-depot.fr/wapt
Published: March 6, 2026 - 09:15
by lelongg
I am Yoni's colleague from Rouen.
We haven't changed the rules since we had secondary repositories; they've always worked with the repository URLhttp://s50dn-depot.ad.in.ac-normandie.fr"(for machines whose name corresponds to *50dn*), it has been a short time since our repositories have been accessed (I would say since version 2.6.1.17705.
Should the URL include the full chin? http://s50dn-depot.ad.in.ac-normandie.fr/wapt/packages ?
2026-03-06 09_14_53-WAPTConsole Enterprise version 2.6.1.17765 [srvwapt.ac-normandie.fr].png
2026-03-06 09_14_53-WAPTConsole Enterprise version 2.6.1.17765 [srvwapt.ac-normandie.fr].png (18.26 KB) Viewed 13201 times
Published: March 6, 2026 - 09:22
by dcardon
Hello Gilles,
the URL is http://s50dn-depot.ad.in.ac-normandie.fr/wapt/
Perhaps there was a fallback to correct the URL before, but the correct repository URL must end with /wapt/. It might have been failing in the past, but now it's correct. :-)
Another small point: for the proxy, you normally need to add the protocol (http://srv-proxy...). I don't know if there's an automatic fallback for it, but normally a URL is expected here.
To ensure that workstations are accessing the secondary repository, you can select "no fallback," so you'll see immediately if it's working correctly or not.
Regards,
Published: March 6, 2026 - 09:26
by lelongg
Thank you!
We will follow this advice.
Best regards,
Gilles
