Page 1 of 1
[RESOLVED] tis-glpi-agent
Published: April 10, 2026 - 10:38 AM
by b.ald
I think the target architecture for the GLPI agent can be changed from "x64" to "all" (for Windows).
I just tested it on a Surface Pro with a Snapdragon processor, and the MSI installs correctly, and the machine inventory is correctly uploaded to the GLPI server.
(The package is version 1.15)
Regards,
Bastien
Re: tis-glpi-agent
Published: April 10, 2026 - 11:04 AM
by gadam
Thank you for the information. Since there is no x86 version (see the repository https://github.com/glpi-project/glpi-agent/releases), I won't switch the architecture to all, but I will provide an arm64 version. Sometimes packages designed for x64 work on arm64, so both versions will point to the same link.
I'll keep you updated as soon as it's published on our store.
Gwenaël
Re: tis-glpi-agent
Published: April 10, 2026 - 11:09 AM
by b.ald
Indeed, since we no longer have any 32-bit workstations in our fleet, I hadn't thought of that.
I'll modify my package again and create a duplicate for arm64. Thank you.
Best regards,
Bastien
Re: tis-glpi-agent
Published: April 10, 2026 - 2:13 PM
by gadam
I've updated our package to version 1.17. I've also created a new x86 version, 1.7.3, the latest version offering a 32-bit installer.
The package should be in pre-production within a few minutes and updated to the production store in 5 days.
Regards,
Gwenaël
