Foxit package shell
Published: May 4, 2026 - 4:33 PM
We are importing the Foxit package in DEV maturity to install it on a few workstations to ensure that there are no side effects.
When we switch the package to PROD, it deletes the "Foxit Software" folders but does not reinstall the software because the version is identical.
Do you think that the deletion of folders should be included in the 'if' condition to correct this typo?
THANKS
THANKS
for to_uninstall in installed_softwares(name="Foxit PDF Reader"):
if Version(to_uninstall["version"]) < Version(control.get_software_version()) or force:
print(f"Removing: {to_uninstall['name']} ({to_uninstall['version']})")
run(uninstall_cmd(to_uninstall["key"]))
wait_uninstallkey_absent(to_uninstall["key"])
old_app_dir = makepath(programfiles32, "Foxit Software", "Foxit Reader")
if isdir(old_app_dir):
remove_tree(old_app_dir)
old_app_dir = makepath(programfiles, "Foxit Software")
# Installing the package
install_exe_if_needed(
bin_name,
silentflags="/quiet",
timeout=900,
name="Foxit PDF Reader",
min_version=control.get_software_version(),
