Page 1 of 1
[RESOLVED] tis-charlemagne-administrative new version not available
Published: May 11, 2026 - 2:12 PM
by admmelyne
I use WAPT to update the Charlemagne software suite.
A new version of Charlemagne Administratif has been available since May 6, 2026: version 13.14.1.0.
Will this new version be available on the WAPT store soon? It seems to me that the publisher, Aplim, no longer makes new versions freely available, but until now it seemed to work with WAPT nonetheless. I am therefore contacting you for information regarding this software suite.
Have a good day :)
Re: tis-charlemagne-administrative new version not available
Published: May 12, 2026 - 08:53
by fschelfaut
This new version is not declared in their API. Until they update their information, we cannot have Luti automatically build new versions.
We have restarted a manual build, and version 13.14.1.0 is now available on the WAPT store.
I suggest you contact the publisher to ensure they properly update their API.
Also note that the Charlemagne Outils executable allows you to retrieve the executables and their versions. However, the information is also outdated there. We are therefore forced to manually download the binaries to verify that they have indeed incremented their versions.
Flavien,
Published: May 12, 2026 - 09:54
by admmelyne
Hi Flavien,
Thanks for your reply.
I contacted Aplim, but so far no one has been able to answer my question about the API update. They should get back to me. I'm afraid they've stopped providing updates. I'll keep you all updated here; perhaps someone here also uses this software suite and goes through Luti to deploy updates across their network.
Thanks for the build!
I can indeed retrieve the executables that way. It's possible that this is the only way now, and therefore I'll have to do manual builds going forward. :/
Published: May 27, 2026 - 4:55 PM
by dcardon
Hello Mélyne,
thank you for the feedback. I'm marking the topic as RESOLVED. If we get more information from Charlemagne, we'll update the topic.
Regards,
