Page 1 of 1
W11 requirements - Reliability issue.
Published: May 18, 2026 - 3:13 PM
by Medea-GH
I'm contacting you with a few questions I haven't been able to find answers to.
We're using the WAPT Discovery version on our network to assess the remaining machines for upgrading to Windows 11.
We launched our agent with the following package:
- Package: tis-windows11-requirements. Version: 2025.10.30-24.
We've noticed that on some PCs, the WAPT audit reports them as "NOT CAPABLE," while Microsoft's PC Health Check tool gives us the green light. (Several machines are showing the same result).
Do you have any ideas, usage tips, or alternatives to ensure the accuracy of the audit results?
Also, we can't navigate the "Audit Data." Is this due to the Discovery version? (See attached file).
Thank you for any help you can provide.
Sincerely.
Re: W11 requirements - Reliability issue.
Published: May 19, 2026 - 09:20
by dcardon
Hello Mede,
Médé-GH wrote: ↑May 18, 2026 - 3:13 PM We are using the Discovery version of WAPT on our network to assess the remaining machines for upgrading to Windows 11.
We therefore launched our agent with the following package:
We noticed that on some PCs, the WAPT audit declares them "NOT CAPABLE," while the Microsoft tool - PC Health Check - gives us the green light. (Several machines are reporting the same result).
What date is the PC Health Check from? Microsoft has added extra limits with each new version of Windows 11. The audit package also checks available disk space; perhaps the disks are full.
Also, we are unable to navigate the "Audit Data" section; is this due to the Discovery version? (See attached file).
Audits are a feature of the Enterprise version. Therefore, it's normal that they're not accessible. You can rewrite the package to print the results within the install() function... Or upgrade to the Enterprise version.
There need to be some differentiating features to attract paying customers and finance Wapt's development; otherwise, there wouldn't be an Enterprise or Discovery version :-).
Published: June 5, 2026 - 4:30 PM
by Medea-GH
Hello Denis,
The PC Health check we are using is very recent, and has been downloaded from the Microsoft website.
The storage on some is completely clean as rarely used, I don't think the issue is there.
Currently we don't have any ideas why there would be some problems on upgrading those to W11.
Thank you very much for your tips.
Best regards,
Médéric.
Published: June 10, 2026 - 10:08
by dcardon
Hello Médéric,
as mentioned in my post, the audit function is not available in the Discovery version. Therefore, if you want to use this package, you need to modify it so that the output is returned during installation to see the result. It's difficult to explain why it returns a different result if we don't have the result itself.
Alternatively, you can create a new package based on the PC Health Check tool.
I will check with the package management team to restrict this package to the Wapt Enterprise client to avoid this issue.
