Page 1 of 1
Secondary repository sync status
Published: May 19, 2026 - 08:19
by Christophe
Following the migration of our main server to Linux (previously on Windows), our secondary repositories, which are still on Windows, remain in a "TO UPDATE" synchronization status. Aside from this, everything seems to be working.
Our version of WAPT is 2.6.1.17787
Do you have any ideas on how to solve this problem?
THANKS
Re: Secondary repository sync status
Published: May 19, 2026 - 09:39
by dcardon
Hi Christophe,
great job on the Windows to Linux server migration! :-)
What message do you get when you click "refresh index"? Is the sync.json file created (with a consistent timestamp) and with the correct permissions? Did you restart the postconf after the update?
Regards,
Published: May 19, 2026 - 1:19 PM
by Christophe
Hi Denis,
So, indeed, we hadn't run the postconf, but that doesn't fix the problem.
Regarding the sync.json file, it's present with a consistent date and time (this morning), and when I select "update index," it says "update sync.json." No error.
Do you have any other ideas?
Published: May 19, 2026 - 2:32 PM
by dcardon
Hi Christophe,
is it Red Hat or a derivative? If so, is SELinux enabled?
Published: May 20, 2026 - 07:50
by Christophe
Denis,
we're on Debian 13 and SELinux is not enabled.
Published: May 26, 2026 - 12:50
by Christophe
Without any intervention on my part, the status has returned to green since last Thursday!
The mysteries of computers have struck again 😉
Thank you and have a good day,
Christophe
Published: May 26, 2026 - 8:54 PM
by vcardon
The gods of computing have been kind to you; this is a sign that you are succeeding. 😁
