Page 1 of 1
[RESOLVED] WAPT 2.6.1 – Direct upgrade to version 17813 or mandatory intermediate step via 17765
Published: June 10, 2026 - 07:58
by PA DEQUIDT
We have a WAPT infrastructure consisting of a main server and 10 secondary repositories.
Currently, our platform is running on version 2.6.1.17705, which is two versions behind the latest available version:
Screenshot 2026-06-10 075233.png (23.69 KB) Viewed 11374 times
Before planning the upgrade, we would like to know if it is possible to go directly from version 2.6.1.17705 to version 2.6.1.17813, or if it is necessary to install the intermediate version 2.6.1.17765 before upgrading to 2.6.1.17813.
Thank you in advance for your feedback and recommendations.
Best regards,
Re: WAPT 2.6.1 – Direct upgrade to version 17813 or mandatory intermediate step via 17765
Published: June 10, 2026 - 09:24
by dcardon
Hello Pierre-Alexis,
it's not necessary to go through the intermediate versions as long as you're in the same major series (here, 2.6). After that, between two major versions, there may be recommended steps to simplify the process, but this is explained in the documentation [1].
Regards,
[1] https://www.wapt.fr/fr/doc/wapt-server-upgrade.html
Published: June 10, 2026 - 2:11 PM
by PA DEQUIDT
Thank you for your feedback.
Pierre-Alexis DEQUIDT
