Page 1 of 1
[SOLVED] Installing wapt agent
Published: July 15, 2026 - 10:17 AM
by Catherine
I manually installed Wapt Agent on a Windows 11 PC (WordGroup), but it's not showing up in my console. Is this normal?
Sincerely, have a nice day.
Re: Installing Wapt agent
Published: July 15, 2026 - 11:37
by dcardon
Hello Catherine,
I imagine the registration is authenticated. When a workstation is in the domain, it uses the machine's Active Directory account to authenticate to the WAPT server. When it's in a workgroup, it only has an Active Directory account it can use, so registration must be done manually with a login/password.
You can run the following command as administrator and use your console credentials.
Published: July 15, 2026 - 11:56 AM
by Catherine
Thank you very much
. Have a lovely day.
