Page 1 of 1
Secondary repository configuration
Published: July 23, 2026 - 2:42 PM
by Mickael
We want to install a secondary repository on a remote site.
We received a procedure from a Tranquil IT technician, which we are following to the letter, but we are encountering some problems.
We use a Raspberry Pi 4B as a remote secondary repository.
Debian Bookworm 64 OS up to date
Server web page information
WAPT Server version: 2.6.1.17834
WAPT Agent version: 2.6.1.17834
WAPT Setup version: 2.6.1.17834
WAPT Deploy version: 2.6.1.17834
company license
When we want to configure the agent with the command sudo wapt-get reset-config-from-url https://"info retrieved from our wapt server's web page"
We have the following message: Access violation
We had already encountered this problem some time ago.
Here is the solution that was provided.
Links: viewtopic.php?t=4495
From what I recall, we previously encountered a gzip support bug on Raspberry Pis as a secondary repository. I thought it had been fixed, but it seems that's not the case... Could you add the line `gzip off;` to your `/etc/nginx/site-enabled/wapt.conf` file on your WAPT server, as shown below?
gzip off;
gzip_min_length 1000;
gzip_buffers 4 8k;
gzip_http_version 1.0;
gzip_disable "msie6";
gzip_types text/plain text/css application/json;
gzip_vary on;
Then restart nginx and try syncing your secondary repository again.
systemctl restart nginx
At the time we performed the procedure and it worked
Today the code is working correctly with gzip vary set to off, on the server side
But we get the error: Access violation
Thank you in advance
Re: Secondary repository configuration
Published: July 24, 2026 - 09:46
by dcardon
Hi Mickaël,
I don't think it's a gzip issue; it should have been fixed some time ago.
If I remember correctly, the custom Raspberry Pi ARM64 kernel introduces (if I recall correctly) non-standard page sizes of 16k which can cause problems [1]. But normally that's for the Pi 5...
However, there were some Access Violation fixes in the latest nightly build [2]. Could you just update the agent on the Raspberry Pi 4?
Regards,
[1] https://www.raspberrypi.com/documentati ... tml#kernel
[2] https://wapt.tranquil.it/wapt/nightly/w ... -d924c912/
Published: August 5, 2026 - 10:51
by Mickael
I only installed the ARM64 agent from the new nightly build:
2.6.1.17860-9bf344f2.
The version is correctly installed: (same result with version 17852)
wapt-get.bin: wapt-get 2.6.1.17860
full-version: 2.6.1.17860-9bf344f2
OpenSSL: OpenSSL 3.5.7 9 Jun 2026
Unfortunately, the problem is still reproducible with the command:
"https://our-server/wapt/conf.d/default_….json"
Consistent result:
Access violation
The following checks were performed:
- Raspberry Pi 4 running Debian Bookworm 64-bit / ARM64;
- gzip disabled on Nginx;
- using the FQDN corresponding to the certificate's SAN;
- URL accessible with curl;
- HTTP 200 response;
- Content-Type application/json;
- JSON file downloaded correctly;
The crash persists with builds 17852 and 17860.
We noticed that the reset address retrieved from the server's web interface appears to have a syntax error
: "wapt-get reset-config-from-url https://our-server//wapt/conf.d/default_.....json"
Thank you.
