Page 1 of 1
[RESOLVED] Added a column to the main display
Published: July 29, 2026 - 2:59 PM
by Julien_
Hello everyone,
I have a fairly basic issue to resolve, but having just returned from vacation, WAPT seems a distant memory.
On my network, I use an Enterprise Resource Planning (ERP) system deployed via Group Policy Objects (GPO). To ensure this ERP was correctly deployed on my workstations, I added the ERP version column by dragging it from the "Software Inventory" tab of a workstation.
Up until now, everything worked perfectly.
Since this morning, I've been updating my ERP, so the version number is changing.
And that's where the problem arises:
I'm performing a batch migration, and on the migrated workstations, the column with the ERP version remains empty.
I tested updating the workstation inventory, and in the main view, the column is still empty.
I checked the "Software Inventory" tab, and I can see my ERP with its new version number.
I foolishly thought I'd try dragging the new version number to see what would happen... but I couldn't drag it to the main display, as if the column were locked.
I tried again with a machine running the old version of the EDR, and there was no problem dragging the version number column.
I can't see what the problem could be; do you have any ideas?
Re: Adding a column to the main display
Published: July 29, 2026 - 3:55 PM
by dcardon
Hi Julien,
have you performed the "software standardization" for this new version in the "software inventory" tab (i.e., entered the same value for both versions of the software in the "Standardized" column)?
Published: July 29, 2026 - 4:02 PM
by Julien_
Ugh... :mrgreen:
I knew it was something simple... well, that means the vacation worked, I had a good brain reset.
Thanks a lot, Denis, that was all it was. ;)
Published: July 30, 2026 - 09:55
by dcardon
Hi Julien,
Julien_ wrote: ↑July 29, 2026 - 4:02 PM I knew it was a simple thing.... well, that means the holidays were effective, I had a good brain reset.
It's going to be my turn to do a brain reset starting tomorrow night... :-)
If you have any further questions, you need to hurry ;-)
Re: [SOLVED] Adding a column to the main display
Published: July 30, 2026 - 3:37 PM
by Jarnaud
I'm adding the link to our documentation to help our clients who might also be taking a well-deserved vacation ^^
You can find it here: https://www.wapt.fr/fr/doc/wapt-console ... ware-names
Best regards
