Page 1 of 1
Problem: Forgotten package
Published: May 13, 2016 - 3:15 PM
by Floflobel
I accidentally added a packet block to all my computers using "CTRL + A". I should have added the packet block to the group.
Now I'm stuck trying to remove it from all the machines... Is there a solution?
For your information, I wanted to remove a packet, but since I can't remotely access the computers, I'm forced to use this method.
Thank you.
Re: Problem forgetting package
Published: May 13, 2016 - 4:15 PM
by sfonteneau
Hi floflobel,
to disable a package "blocking" you can use the opposite function, which is "allow packages".
For your information, to remove a package in bulk, I use a fixup package.
Basically, I have an smp-fixupwapt package assigned to all PCs to regularly correct small mistakes and tweaks I want to make.
smp-fixupwapt is available here:
https://wapt.lesfourmisduweb.org/wapt/
So even if the machine is turned off, the fix will still be applied later. This isn't possible with the package removal command in the console,
Simon.
Published: May 13, 2016 - 4:22 PM
by Floflobel
Thanks for your help, "Allow package" works perfectly.
I'll take a closer look at your package, but at first glance it looks very interesting. ;)
Published: May 13, 2016 - 4:28 PM
by Floflobel
Where do you find functions like WAPT.is_installed?
I looked in setuphelpers but I don't see anything.
Published: May 13, 2016 - 5:29 PM
by sfonteneau
Published: May 18, 2016 - 12:39
by Floflobel
Perfect, thank you!
