[SOLVED] WAPT agent on raspberry pi zero rev2015
gcalvez
Registration: Nov 15, 2019 - 3:15 p.m.
October 15, 2026 - 11:19
on my Raspberry Pi Zero (Debian Trixie), the armhf agent 2.7.0.19593 is not working.
I understand that Pi Zeros run on armv6 and not armv7.
Is this a plausible explanation?
I get this error at runtime:
An unhandled exception occurred at $00032B50:
EAccessViolation: Access violation
$00032B50.
Otherwise, everything else works. The server is on Debian Trixie (discovery), several agents work on Trixie, Ubuntu 26.04, and Windows 11... as well as the armhf version on a Raspberry Pi 4.
Thank you.
October 15, 2026 - 1:14 PM
I have a ticket about this, but the client hasn't called to look into it with him.
Please call our support line so we can look into it together.
gcalvez
October 15, 2026 - 1:34 PM
I'm not requesting commercial support for such a small thing. If the armhf binaries aren't compatible with armv6, I'll simply replace the Pi Zeros with Pi 4s.
Have a good day.
October 15, 2026 - 2:06 PM
gcalvez wrote: ↑Oct 15, 2026 - 1:34 PM I'm not asking for sales support for so little
This will be free support in this case (it's a problem in Wapt that I can't reproduce here)
gcalvez
October 15, 2026 - 2:50 PM
My Pi Zeros are "version 1", with BCM2835 chips and an ARM1176JZF-S processor; apparently, this version has been discontinued since 2005.
I think it's time I replaced them.
Pi Zero version 2s use a BCM2710A1, a 64-bit Arm Cortex-A53 processor
October 15, 2026 - 3:25 PM
Hi Guillaume,
indeed, it won't work on Pi 0 rev1s... I do have a Raspberry Pi 1 Model B lying around. When I have some time, I'll look into what can be done with it for WAPT. That said, it's really, really slow. A Raspberry Pi 4 is a supercomputer by comparison. :-)
Note: if you're using Raspberry Pi 5s, you need to be careful about the type of kernel loaded. The default Raspberry Pi kernel has a non-standard memory page size, and that causes problems. You need to use a "normal" kernel.
I'm marking this topic as resolved.
Best regards,
