Page 1 of 1
build-waptagent and certificate import
Published: October 15, 2026 - 4:27 PM
by madeolde
Does the "wapt-get build-waptagent" command allow specific certificates to be included when generating the agent?
I tried, among other things, using -p to pass a .json file including my certificates, but without success.
wapt-get build-waptagent /ConfigFilename "fichier.ini" -p "fichier.json" --wapt-server-user=user --wapt-server-passwd=passwd --private-key-passwd=passwd
I need to be able to generate command-line agents after a server update, and these agents will need to include 2 certificates. They will then be deployed via GPO.
Thank you for your help!
Our server is currently on version 2.6.1, the console is running Windows 11.
