Page 1 of 1
WAPT: My opinion
Published: July 18, 2016 - 10:53 AM
by Ekouyoja
First of all, I want to congratulate you on the work done on this solution, which is, in my opinion, one of the most intuitive and functional—a rare combination these days! ^^
I just have two minor criticisms:
- First, multi-repo functionality on Windows can only be set up if you know the magic formula.
- Second, the task tab in the console, regardless of the machine, is buggy and doesn't allow us to see the full description, which can be irritating. :D
Otherwise, I can only recommend WAPT to those who are still hesitating.
Re: WAPT: My opinion
Published: April 2, 2018 - 11:28 PM
by vcardon
Thanks Ekouyoja for your encouragement.
You must have seen that things have progressed a lot since your super encouraging post.
I hope you're still having a blast with WAPT and that you're recommending it to your friends and even your most beloved enemies, despite our late reply to your post.
Best regards,
Vincent
