Page 1 of 1
Problem with the "SKYPE" package
Published: August 24, 2016 - 11:53
by cedric.pimont
for some time now I've been having trouble with the "Skype" package; the updates won't install. I therefore added the latest version of the "Skype" package, and now it's even worse. It uninstalls the version of Skype that's already on my PC and doesn't install the latest version; I get an error. Can you help me?
Here is the message I received:
4 - 2016-08-23T17:44:31.674000 - Installing fga-skype(=7.18.0.103-6) (task #4): Installing fga-skype
Exception: Error installing fga-skype(=7.18.0.103-6): {'skipped': [], 'additional': [], 'downloads': {'downloaded': [], 'skipped': [u'C:\\Program Files (x86)\\wapt\\cache\\fga-skype_7.18.0.103-6_all.wapt'], 'errors': []}, 'remove': [], 'upgrade': [], 'install': [(u'fga-skype(=7.18.0.103-6)', PackageEntry('fga-skype','7.18.0.103-6'))], 'errors': [[u'fga-skype(=7.18.0.103-6)', PackageEntry('fga-skype','7.18.0.103-6')]], 'unavailable': []}
File "C:\Program Files (x86)\wapt\waptservice\waptservice.py", line 1982, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice.py", line 1247, in pwrapper
return func(*arg, **kwargs)
File "C:\Program Files (x86)\wapt\waptservice\waptservice.py", line 1307, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice.py", line 1732, in _run
raise Exception(__('Error during install of {}:{}').format(self.packagename,self.result))
Exception: Error during installing fga-skype(=7.18.0.103-6): {'skipped': [], 'additional': [], 'downloads': {'downloaded': [], 'skipped': [u'C:\\Program Files (x86)\\wapt\\cache\\fga-skype_7.18.0.103-6_all.wapt'], 'errors': []}, 'remove': [], 'upgrade': [], 'install': [(u'fga-skype(=7.18.0.103-6)', PackageEntry('fga-skype','7.18.0.103-6'))], 'errors': [[u'fga-skype(=7.18.0.103-6)', PackageEntry('fga-skype','7.18.0.103-6')]], 'unavailable': []}
3 - 2016-08-23T17:44:13.450000 - Installing fga-skype(=7.24.0.104-7) (task #3): Installing fga-skype
Exception: Error installing fga-skype fga-skype(=7.24.0.104-7): {'skipped': [], 'additional': [], 'downloads': {'downloaded': [], 'skipped': [u'C:\\Program Files (x86)\\wapt\\cache\\fga-skype_7.24.0.104-7_all.wapt'], 'errors': []}, 'remove': [], 'upgrade': [], 'install': [(u'fga-skype(=7.24.0.104-7)', PackageEntry('fga-skype','7.24.0.104-7'))], 'errors': [[u'fga-skype(=7.24.0.104-7)', PackageEntry('fga-skype','7.24.0.104-7')]], 'unavailable': []}
self._run()
Exception: Error during installing fga-skype(=7.24.0.104-7): {'skipped': [], 'additional': [], 'downloads': {'downloaded': [], 'skipped': [u'C:\\Program Files (x86)\\wapt\\cache\\fga-skype_7.24.0.104-7_all.wapt'], 'errors': []}, 'remove': [], 'upgrade': [], 'install': [(u'fga-skype(=7.24.0.104-7)', PackageEntry('fga-skype','7.24.0.104-7'))], 'errors': [[u'fga-skype(=7.24.0.104-7)', PackageEntry('fga-skype','7.24.0.104-7')]], 'unavailable': []}
Re: Problem with the "SKYPE" package
Published: August 24, 2016 - 3:19 PM
by cedric.pimont
I have an answer to my problem:
the package is not compatible with my version of WAPT.
