Page 1 of 1
backslash in command run
Published: September 13, 2016 - 12:27 PM
by the Challans Town Hall
I'm trying to run a command in the pyton.py file, but each time my backslashes are doubled and the command fails.
The same problem persists, c:\ is interpreted as c:\\.
The command to execute is:
powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\
run(r'powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\')
run(r'"powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\"')
Or
commandsm=r"powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\"
run(commandsm)
All these commands return the following to me:
2016-09-13 11:58:29,858 CRITICAL Fatal error in install script: CalledProcessError: Command '('"powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\\ -verbose"',)' returned non-zero exit status 1:Traceback (most recent call last):
  File "C:\wapt\common.py", line 3166, in install_wapt
  File "c:\users\adminv~1\appdata\local\temp\waptxfvtxf\setup.py", line 71, in install
    run(r'"powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\ -verbose"')
  File "C:\wapt\common.py", line 3013, in run
    return setuphelpers.run(*arg,pidlist=self.pidlist,**args)
  File "C:\wapt\setuphelpers.py", line 602, in run
    raise subprocess.CalledProcessError(proc.returncode,cmd,''.join(output))
2016-09-13 11:58:29,940 CRITICAL Package chal-config-pc not installed due to errors : CalledProcessError: Command '('"powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\\ -verbose"',)' returned non-zero exit status 1
How can I keep the "c:\" character intact in the run command?
THANKS.
Re: Backslash in command run
Published: September 13, 2016 - 4:01 PM
by fludo67
Have you tried using the escape character \? (c:\\)
commandsm=r'powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath c:\\'
Published: September 16, 2016 - 11:09 AM
yes, and so it looks like this: c:////
(all backslashes are doubled)
:twisted:
Published: September 19, 2016 - 09:44
by Aedenth
I don't know if this is the best way to do it, but using the following code should work.
command = r"powershell -NoProfile -NoLogo -NonInteractive -Command import-startlayout -layoutpath screenlayout.bin -mountpath "
path = os.path.normpath('C:\\')
commandsm = ''.join([command,path])
run(commandsm)
Published: September 19, 2016 - 3:24 PM
Thank you, this solution works!
