Page 1 of 1
Automatic reporting of installed software (e.g., via email)
Published: October 6, 2016 - 9:18 AM
by Remi Pinck
we have been using Wapt with satisfaction for some time now.
Currently, users do not have the admin password to install new programs except in certain special cases (developers, etc.).
For these "special cases," we would like to have an automatic report of new software installed during the day so that we can remove pirated software as quickly as possible.
Is there a way to do this with Wapt?
Thank you and have a good day
, Rémi Pinck
Re: Automatic reporting of installed software (e.g., by email)
Published: October 7, 2016 - 3:32 PM
by sfonteneau
Remi Pinck wrote:Hello,
One could easily imagine a package that installs itself every time the machine shuts down
computer shutdown script:
wapt-get install -f tis-scanpackage
And this program scans the software list each time; if the software list has changed since the last scan, the package sends the name of the affected software via email with blat
So yes, it's possible
Published: October 7, 2016 - 4:37 PM
by htouvet
Here's a small example script to put in c;\wapt\softaudit.py that does the job...
Then, in a command prompt, run `waptpython c:\wapt\softaudit.py --days=5`
import sys,os
from common import *
from getpass import getpass
from optparse import OptionParser
def compact_date(adatetime=None):
if adatetime is None:
adatetime = datetime.datetime.today()
return adatetime.strftime('%Y%m%d')
if __name__ == '__main__':
parser=OptionParser(usage="Sample script which check softwares installed recently on wapt registred computers")
parser.add_option("-c","--config", dest="config", default=os.path.join(os.path.dirname(sys.argv[0]),'wapt-get.ini') , help="Config file full path (default: %default)")
parser.add_option("-d","--days", dest="days", default=1, type='int', help="Days back to look at (default: %default)")
(options,args) = parser.parse_args()
server_password = getpass('Please input wapt server admin password:')
# initialise wapt api with local config file
wapt = Wapt(config_filename = options.config)
wapt.dbpath=':memory:'
# get the collection of *all* hosts from waptserver inventory
hosts = wapt.waptserver.get('api/v1/hosts?columns=uuid,host.computer_fqdn',auth=('admin',server_password))
print(u'Logiciels installés depuis %s jours sur les %s machines de wapt:\n'%(options.days,len(hosts['result'])))
for h in hosts['result']:
try:
uuid = h['uuid']
hostname = h['host']['computer_fqdn']
ip = ','.join(h['host']['connected_ips'])
description = h['host']['description']
softs = wapt.waptserver.get('api/v1/host_data?uuid=%s&field=softwares'%(uuid,),auth=('admin',server_password)).get('result',[])
datemin = compact_date(datetime.datetime.now()-datetime.timedelta(days=options.days)) # forme YYYYMMDD 20161007
recent_installs = [s['name'] for s in softs if s['install_date'] >= datemin]
if recent_installs:
print "%s (%s) %s:\n %s\n" %(hostname,ip,description,'\n '.join(recent_installs))
except Exception as e:
print " error %s" % e
Published: October 10, 2016 - 10:22 AM
by Floflobel
it's very difficult to put the WAPT admin password in plain text. Someone with even a little technical knowledge could easily guess it.
Isn't there another solution?
Published: October 13, 2016 - 10:34 AM
by Remi Pinck
thank you for the script suggestion (I will forward it to the admin who manages the project).
Indeed, the password issue still needs to be resolved.
Have a good day,
Rémi.
