Page 1 of 1
Sketchup Package
Published: Dec 12, 2016 - 5:02 PM
by gaelds
I'm having a lot of trouble installing SketchUp Make 2017; it only works on a few PCs. Is it possible to disable the uninstall key verification at the end of the WAPT package installation? On my PC (Windows 7 64-bit), I get the following message:
Otherwise, on a room with 6 PCs running XP, I get the following message:
Installing dst-sketchup2016
EWaptSetupException: Fatal error: MSI SketchUp2016-x86.msi has been installed but the uninstall key
{CF062509-06B2-4F57-9373-166B04719F94} can not be found
And on the same PCs with the 2015 version:
installing dst-sketchup2015
Exception: The uninstall key: {A1391613-0694-43DF-A4FC-144CC26BCDCB} has not been found in system registry after software installation.
Still in the same room, the teacher's PC (identical to mine, a Dell 3020 running Windows 7 64-bit) successfully installs version 2017 + VC2015 + .NET FX4.5, but nothing happens when you click on it…
import platform
# registry key(s) where WAPT will find how to remove the application(s)
# command(s) to launch to remove the application(s)
uninstallstring = []
# list of required parameters names (string) which can be used during install
required_params = []
    # if you want to modify the keys depending on environment (win32/win64... params..)
    global uninstallkey
    global uninstallstring
    softname = 'Sketchup'
    versionsoft = '16.1.1450'
    check_installed_soft = installed_softwares(softname)
    if check_installed_soft:
                key=uninstall['key']
                if installed_softwares(uninstallkey=key):
                   if Version(uninstall['version']) < Version(versionsoft):
                         run_notfatal(cmd)
    if iswin64():
        print('Installation de sketchup 2017')
        install_msi_if_needed('SketchUp2017-x64.msi',killbefore=['SketchUp.exe'])
        uninstallkey.append('{F124B571-EFA9-40F2-81B3-32AB0232429A}')
        print('installing dst-sketchup2016')
        install_msi_if_needed('SketchUp2016-x86.msi',killbefore=['SketchUp.exe'])
        uninstallkey.append('{CF062509-06B2-4F57-9373-166B04719F94}')
Re: Sketchup Package
Published: Dec 13, 2016 - 08:05
by gaelds
Following Simon's advice, I removed the uninstallkey.append( and it works better on my PC. For the PC where the software won't launch, it's a driver update that's needed. And for XP, SketchUp is no longer compatible since version 2015...
Published: November 25, 2020 - 10:57 AM
by Jean Baudin
gaelds wrote: ↑Dec 12, 2016 - 5:02 PM I'm having a lot of trouble installing SketchUp Make 2017; it only works on a few PCs. Is it possible to disable the uninstall key verification at the end of the WAPT package installation? On my PC (Windows 7 64-bit), I get the following message:
import platform
    global uninstallkey
                         run_notfatal(cmd)
    if iswin64():
Hi, were you able to find an answer to your problem on Sketchup?
Published: November 25, 2020 - 6:10 PM
by jpele
Coincidentally, we updated the package today on the Store. I invite you to try it out.
https://store.wapt.fr/store/tis-sketchup-make
Jimmy
Published: Dec 16, 2020 - 08:24
by Jean Baudin
jpele wrote: ↑Nov 25, 2020 - 6:10 PM Hello,
, https://store.wapt.fr/store/tis-sketchup-make
we updated the package today on the Store. I invite you to test it.
Jimmy
Thanks, I'll go take a look at all of that :D
