Slowdown issue in version 1.3.8.2
Published: Dec 14, 2016 - 11:21
since upgrading to version 1.3.8.2, the server's search behavior has changed. Displaying results is extremely slow, which wasn't the case with version 1.2.3.
It's worth noting that the server handles 2200 workstations, but this was also true with the previous version.
The problem is that in the search field, you can't enter a single character without the server searching for the specified value. Therefore, a lengthy search is performed after each character, significantly increasing the processing time. Consequently, you have to copy and paste the entire string of characters you want to search for to ensure it's fully recognized.
Furthermore, the console takes approximately 4 minutes to load before appearing on the server.
That's my experience.
