Inconsistencies between web console and
Published: Dec 14, 2016 - 11:54
I've noticed that in rare cases, commands entered in the DOS console, such as `wapt-get install firefox`, sometimes return an "Unavailable " response , as if the package couldn't be found on the server.
From there, I open a web console and install the application using the 'Install' link associated with the target application that had responded that it was invalid. And then it works. The package installs.
Why is the information inconsistent between the DOS console and the web console? Is there a configuration setting I need to review?
Thank you.
Thank you.
