Page 1 of 1
Questions about WAPT features
Published: Dec 28, 2016 - 3:06 PM
by Yannka
I'm looking for a solution to meet my needs.
The need:
To allow users to access an application catalog so they can select the applications they want on their workstations. Once selected, the application would install itself on the workstation.
Main constraint:
Multiple forests, without existing trust relationships.
Solutions considered:
Kace K1000,
SCCM
, WAPT.
My question:
I'd like to know if WAPT meets my needs, taking into account the major constraint of my project?
Thank you for your response.
Re: Questions about WAPT features
Published: Dec 29, 2016 - 1:50 PM
by sfonteneau
Yannka wrote:Hello,
The need:
To allow users to access an application catalog so they can select the applications they want on their computers. Once selected, the application would install itself on the computer.
The feature you are looking for on wapt is the waptselfservice feature
Users in the domain's waptselfservice group can install packages
Yannka wrote:
Main constraint:
Multi-forests, with no existing trust relationships.
Simply create a waptselfservice group on each forest
Kace K1000
SCCM
WAPT
My question:
I am trying to find out if WAPT meets my needs while taking into account the major constraint of my project?
Apparently so.
Published: Dec 30, 2016 - 11:24
by Yannka
Thank you for the reply.
sfonteneau wrote:
Yannka wrote:
Main constraint:
Let's imagine that I install the server on forest A.
Then, by creating a waptselfservice group on forests B, C, D and E, is that enough to connect to the server on forest A?
Let me reiterate: forests do not communicate with each other at all.
Published: Dec 31, 2016 - 10:49
by sfonteneau
The remote sites don't communicate with each other?
It's still possible, but it all depends on the operating mode you want; Wapt is very modular.
Can you describe the constraints of your project in more detail?
The forests
