Page 1 of 1
managing security on a folder after deployment
Published: February 28, 2017 - 11:36 AM
by gbt
in a package I run a script at the end that should grant rights to a domain group on a directory of the deployed application.
My script, essai.bat, is:
icacls c:\temp\essai.txt /T /grant "adgroup@mydomain":f
icacls c:\temp\essai.txt /T /grant "everyone":r
The result: the "everyone" group is added, but not the domain group.
Manually running the script gives the expected result.
Thank you all.
Re: Managing security on a folder after deployment
Published: March 24, 2017 - 2:26 PM
by agauvrit
Is this script called by the setup.py file in the WAPT package?
Have you tried executing these lines directly in a run() command?
run([makepath(WAPT.wapt_base_dir,'vc_redist','icacls.exe'),r'c:\temp\essai.txt','/T /grant "adgroup@mondomaine":f'])
run([makepath(WAPT.wapt_base_dir,'vc_redist','icacls.exe'),r'c:\temp\essai.txt','/T /grant "tout le monde":r'])
Alexander
Published: May 9, 2017 - 8:23 AM
by gbt
Hi agauvrit,
the script is indeed called from setup.py.
Thank you for the tip about wapt's icacls: it works with a run. :D
Thanks for your help,
Olivier
Published: October 24, 2017 - 09:21
by gaelds
I've tried several different settings for icacls but I keep getting a "returned non-zero exit status 87" error
What settings are needed to grant access to a folder to all users or everyone?
 run([makepath(WAPT.wapt_base_dir,'vc_redist','icacls.exe'),r'C:\Program Files\SolidWorks Corp','/grant *S-1-1-0:(OI)(CI)M /C /T'])
CalledProcessErrorOutput: Command ['C:\\wapt\\vc_redist\\icacls.exe', 'C:\\Program Files\\SolidWorks Corp', '/grant *S-1-1-0:(OI)(CI)M /C /T'] returned non-zero exit status 87.
Output:u'Param\xe8be invalid \xab\xa0/grant *S-1-1-0:(OI)(CI)M /C /T\xa0\xbb\r\r\n'
The control operates manually.
Published: October 24, 2017 - 2:54 PM
by agauvrit
Slashes in arguments are interpreted differently; try putting an 'r' in front of the argument list:
run(makepath(WAPT.wapt_base_dir,'vc_redist','icacls.exe'),r'C:\Program Files\SolidWorks Corp',r'/grant *S-1-1-0:(OI)(CI)M /C /T')
Alexander
Published: November 6, 2017 - 10:12 AM
by gaelds
So I'm getting a new error message: TypeError: unsupported operand type(s) for +: 'float' and 'str'
with this command:
Published: January 9, 2018 - 11:13 AM
by gaelds
Sorry, but I'm still stuck using icacls with wapt. On another package where I want to give all users permissions to a directory, I get the following message:
for the following code:
run(makepath(WAPT.wapt_base_dir,'vc_redist','icacls.exe'),r'%s' %destdir,r'/grant *S-1-1-0:(OI)(CI)M /C /T')
The equivalent command launched manually works:
C:\wapt\vc_redist\icacls.exe C:\ProFluid44 /grant *S-1-1-0:(OI)(CI)M /C /T
