Page 1 of 1
[SOLVED] Purple Pen Setup.py
Published: April 5, 2017 - 12:06 PM
by agatoi
Hello everyone,
Below is the setup.py file for the Purple Pen software. Purple Pen is a map editor primarily used in orienteering.
Download link for the .exe file: http://purplepen.golde.org/download.htm
#def install():
#    print('installing aiz-purplepen')
#    run(r'"purplepen-262.exe" /VERYSILENT')
#uninstallkey = ['{3A0A803D-20BC-4137-AD76-C242AEED29AC}']
#unistallstring="MsiExec.exe /X{3A0A803D-20BC-4137-AD76-C242AEED29AC}"
    versionpaquet = control['version'].split('-',1)[0]
    versionpaquet_02 = versionpaquet.replace('.','')
    install_exe_if_needed("purplepen-"+versionpaquet_02+".exe",
                        silentflags="/S /v/qn",
                        key="{3A0A803D-20BC-4137-AD76-C242AEED29AC}",
                        min_version=versionpaquet,
                        killbefore="PurplePen.exe")
