Page 1 of 1
Creating MSI packages via click/drop
Published: April 19, 2017 - 4:29 PM
by avondra
I'm having trouble with the new drag-and-drop feature for creating .msi packages in the private repository.
Instead of a "+", I get a "Forbidden" symbol when I drag the package, even though I'm on version 1.3.12.3.
Do you have any ideas?
Thanks for your great work!
Re: Creating an MSI package via click/drop
Published: April 19, 2017 - 5:54 PM
by sfonteneau
https://lists.tranquil.it/pipermail/wap ... 02240.html
Actually, to be more precise, it's because of User Account Control (UAC), and it's precisely because it's running as administrator that drag and drop doesn't work.
Published: April 20, 2017 - 3:03 PM
by avondra
Hello Simon,
I disabled UAC but it didn't change anything...
I'm also having trouble connecting to the public package server; I'm getting a certificate error. Are you experiencing any issues on your end?
File "
File "C:\Program Files (x86)\wapt\waptdevutils.py", line 165, in update_external_repo
packages = repo.search(search_string,newest_only=newest_only)
File "C:\Program Files (x86)\wapt\waptpackage.py", line 700, in search
for package in self.packages:
File "C:\Program Files (x86)\wapt\waptpackage.py", line 1190, in packages
self._load_packages_index()
File "C:\Program Files (x86)\wapt\waptpackage.py", line 1151, in _load_packages_index
packages_answer = requests.get(self.packages_url,proxies=self.proxies,timeout=self.timeout, verify=self.verify_cert,headers=default_http_headers())
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\api.py", line 69, in get
return request('get', url, params=params, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\api.py", line 50, in request
response = session.request(method=method, url=url, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 471, in request
resp = self.send(prep, **send_kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 579, in send
r = adapter.send(request, **kwargs)
File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 430, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:590)
- 2017-04-20 14_59_03-Console WAPT.png (5.3 KB) Viewed 8997 times
THANKS
Published: April 20, 2017 - 5:55 PM
by avondra
The certificate issue has been resolved, however drag and drop still doesn't work despite UAC being disabled.
Alain
Published: April 20, 2017 - 10:09 PM
by sfonteneau
I just tried again:
UAC disabled (see doc) (don't forget the restart) Works perfectly.
Otherwise, go to Tools --> Create a package template from an installer --> choose an installer... it's exactly the same!
Published: April 21, 2017 - 3:10 PM
by avondra
Everything is working perfectly now. I had to disable UAC via the registry because I couldn't do it through the Control Panel, even as an administrator. Perhaps you could add this option to the documentation, which is already very well done.
1) Open the Windows Registry Editor (regedit):
2) Go to the key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System]
3) Change "EnableLUA" by setting its value to "0" (zero).
4) Restart the machine.
Thank you.
Published: April 21, 2017 - 5:10 PM
by agauvrit
indeed, disabling UAC is a bit trickier in Windows 10 than in Windows 7.
A package might do it someday, perhaps.
Alexandre
