Page 1 of 1
Remove the Wapt agent for a clean reinstallation.
Published: April 24, 2017 - 2:28 PM
by rlarche2
I'd like to remove the WAPT agent from my network using Group Policy. But I don't know how to remove the remaining folder after uninstallation other than manually on each machine...
Could you please help me?
Thank you.
Re: Removing the Wapt agent for a clean reinstallation.
Published: April 24, 2017 - 11:11 PM
by agauvrit
Have you tried using an Active Directory Group Policy Preference (GPP) to delete a folder?
For example:
https://superuser.com/questions/842235/ ... ective-sho
Otherwise, you can always overwrite the WAPT agent installation and create a package that cleans up what's causing the problem.
Regards,
Alexandre
Published: June 19, 2017 - 1:53 PM
by Mika
we are going to reinstall a WAPT server and redeploy the agents on our workstations.
Would you advise me to delete the agents before creating a new GPO, or is reinstalling with the new settings sufficient?
Published: June 19, 2017 - 2:20 PM
by agauvrit
Hi Mika,
WAPT allows for the overwriting of an existing installation, so you can proceed without worry and deploy the new version of the WAPT agent via GPO; it's a proven technique.
Alexandre
