Page 1 of 1
Incorrect version in console view
Published: May 2, 2017 - 12:49
by Omahaddict
I just updated to version 1.3.12.13 and I'm encountering a problem that seems to be just a display issue, but I find it strange:
All workstations were updated with the waptupgrade package, and some have version 1.3.8.2 (or even 1.3.5...) in the WAPT version column of the console.
However, the binaries on the workstations are indeed those of version 1.3.12.13.
I should mention that software deployments are working correctly on all workstations.
Is there a command to run or a file to modify on the workstations to ensure the reported version is correct?
Thank you for your help.
