Page 1 of 1
[Resolved] Firefox 53.0.2-93 installation/update
Published: May 16, 2017 - 4:45 PM
by IiscsiI
Hello everyone,
WAPT Server version: 1.3.12.13
WAPT Agent version: 1.3.9.3
WAPT Setup version: 1.3.9.3
WAPT Deploy version: 1.3.12.3
I updated the Firefox package on my console and when installing it on the PCs I get the following error message:
Installing waptp-firefox
Exception: Error during install of waptp-firefox (=53.0.2-93): errors in packages [[u'waptp-firefox (=53.0.2-93)', PackageEntry('waptp-firefox','53.0.2-93')]]
  File "c:\wapt\waptservice\waptservice.py", line 2099, in run
    self.running_task.run()
  File "c:\wapt\waptservice\waptservice.py", line 1360, in pwrapper
    return func(*arg, **kwargs)
  File "c:\wapt\waptservice\waptservice.py", line 1420, in run
    self._run()
  File "c:\wapt\waptservice\waptservice.py", line 1844, in _run
If I activate the "tray" the message "wrong version of WAPT" appears.
Did I miss a step during my update?
1 - my packages
dpkg --status tis-waptserver tis-waptrepo tis-waptsetup
Package: tis-waptserver
Status: install ok installed
Priority: optional
Section: base
Maintainer: TIS <technique@tranquil-it-systems.fr>
Architecture: all
Version: 1.3.12.13
Depends: python, mongodb-server (>= 2.4.8), dialog, tis-waptrepo, python-m2crypto, python-passlib, uwsgi, uwsgi-plugin-python, python-tz, cabextract, python-netifaces, python-urllib3, python-requests
Recommends: tis-waptsetup, uwsgi-plugin-http
Description: WAPT Server for linux
Package: tis-waptrepo
Priority: optional
Section: base
Maintainer: Tranquil-IT-Systems <admin@tranquil-it-systems.fr>
Architecture: all
Version: 1.3.12.13
Depends: python, apache2, python-requests
Description: serveur depot wapt local
Homepage: http://www.tranquil-it-systems.fr
Package: tis-waptsetup
Priority: optional
Section: base
Architecture: all
Version: 1.3.12.13
Depends: tis-waptrepo
Description: WAPT setup executable for Windows
2 - command post conf /usr/bin/python /opt/wapt/waptserver/scripts/postconf.py -> Done and OK
3 - Install the console in its new version
4 - generate a new agent.
But the console and the agent remain at version 1.3.9.3.
Thanks in advance
Re: Firefox 53.0.2-93 Installation/Update
Published: May 17, 2017 - 09:03
by Stenon
Hi
Have you installed the new version on your Windows computer that manages WAPT packages?
Otherwise, go to your server's web address and install it
◾WAPTSetup (for installing on management machine)
Then you just need to generate the agent package...
Published: May 18, 2017 - 08:43
by IiscsiI
thank you for your reply.
I found the problem. My client update package hadn't installed correctly and was generating an "unknown" error during client installation.
I regenerated it and it's working much better now, so we can close the issue as far as I'm concerned.
Have a good day.
