Page 1 of 1
Problem: Console Error Replication Repository
Published: August 1, 2017 - 1:57 PM
by neckatskin
After testing a configuration of your WAPT solution on Windows Server, I decided to set up a WAPT infrastructure on Linux, as I'm particularly interested in repository replication. I followed your tutorial to set up replication with Syncthing and I didn't encounter any apparent problems.
However, when I returned to my Windows machine, where I installed the administration console, an error message appeared and prevented the console from opening: "MissingSectionHeaderError" (see attached image).
I really have no idea what this error could mean. Please feel free to contact me if you need more information about the configuration on my infrastructure or any logs (please specify their location) that might help you understand the problem.
Thank you in advance,
NeckAtSkin
Re: Console Error Problem Replication Repository
Published: August 2, 2017 - 11:43
by sfonteneau
Your file
%appdata%\..\Local\waptconsole\waptconsole.ini appears to be corrupted.
Delete it; it will recreate itself the next time you open the console.
- Simon
Published: August 2, 2017 - 12:24
by neckatskin
I worked around the problem by using a separate VM for the console; I'll try your suggestion if I encounter this issue again. Thank you for your reply. ;)
