[Solved] session-setup still launches powershell in 32bits
Published: August 4, 2017 - 10:57
I admit it's quite convoluted, so I'm turning to you to see if anyone has any insights
My PowerShell script:
The end of session-setup :
And the logs tell me:
Amazing, isn't it? The application name, with the full path, is correct, and yet it launches the 32-bit version. But the 32-bit version doesn't have half the commands I need. Thanks, Microsoft.
$ErrorActionPreference="SilentlyContinue"
Stop-Transcript | out-null
$ErrorActionPreference="Continue"
Start-Transcript -path c:\tmp\Win10.log -append
if ([Environment]::Is64BitProcess) {
echo "64 bit powershell" }
Else { echo "32 bit powershell" }
Stop-Transcript
cmd="c:\\Windows\\System32\\WindowsPowershell\\v1.0\\powershell.exe -NoProfile -NonInteractive -ExecutionPolicy Bypass -File c:\\tmp\\Win10.ps1"
run(cmd,timeout=7200)Code: Select all
Début de la transcription Windows Powershell
Heure de début : 20170804094010
Nom d'utilisateur : DESKTOP-IJCDS8M\bobby
Utilisateur runAs : DESKTOP-IJCDS8M\bobby
Ordinateur : DESKTOP-IJCDS8M (Microsoft Windows NT 10.0.15063.0)
Application hôte : c:\Windows\System32\WindowsPowershell\v1.0\powershell.exe -NoProfile -NonInteractive -ExecutionPolicy Bypass -File c:\tmp\Win10.ps1
ID de processus : 3080
PSVersion: 5.1.15063.502
PSEdition: Desktop
PSCompatibleVersions: 1.0, 2.0, 3.0, 4.0, 5.0, 5.1.15063.502
BuildVersion: 10.0.15063.502
CLRVersion: 4.0.30319.42000
WSManStackVersion: 3.0
PSRemotingProtocolVersion: 2.3
SerializationVersion: 1.1.0.1
Transcription démarrée, le fichier de sortie est c:\tmp\Win10.log
32 bit powershell
