Page 1 of 1
creating a firefox esr package
Published: August 29, 2017 - 11:11
by viken
I just installed Wapt for my community. It seems perfectly suited to our needs.
I would like to deploy Firefox ESR without the maintenance service as a test.
I haven't found any information on whether this is possible or how to do it.
Has anyone succeeded?
Thank you for your help. Sincerely,
Vikèn Amtablian
Re: Creating a Firefox ESR package
Published: August 29, 2017 - 11:36
by sfonteneau
Hello
, according to the Firefox documentation:
https://wiki.mozilla.org/Installer:Comm ... _Arguments,
you can pass an .ini file during installation.
Published: August 30, 2017 - 12:15
by viken
thank you for the information. Indeed, there are many possibilities.
However, I'm getting an error when debugging the installation:
EWaptSetupException: Fatal error: setup exe file Firefox_52.3.0esr.exe -INI=C:\waptdev\TEST_Firefox_52.3.0_ESR-wapt\firefox_setup.ini not found in package.
There are no errors when I delete /INI=C:\\waptdev\\TEST_Firefox_52.3.0_ESR-wapt\\firefox_setup.ini.
I imagine there's a syntax error, but I can't see where, as I'm not very familiar with this yet.
Here is my setup.py file
: def install():
print('installing TEST_Firefox_52.3.0_ESR')
install_exe_if_needed("Firefox_52.3.0esr.exe /INI=C:\\waptdev\\TEST_Firefox_52.3.0_ESR-wapt\\firefox_setup.ini",
key='Mozilla Firefox 52.3.0 ESR (x86 fr)',
min_version='52.3.0' ,
killbefore="firefox.exe")
Published: August 30, 2017 - 1:18 PM
by sfonteneau
More like this
install_exe_if_needed("Firefox_52.3.0esr.exe /INI=%s",
killbefore="firefox.exe" % makepath(basedir,"firefox_setup.ini") )
