Page 1 of 4
WAPT 1.3 to 1.5 Migration Error
Published: Dec 8, 2017 - 1:43 PM
by tech62
After following the instructions on the wiki, I still encounter the error:
Version: .5.1.9-tisdeb9-4420-1134da77
mongodb process running, need to migrate
sh: 1: mongoexport: not found
File "/opt/wapt/waptserver/waptserver_upgrade.py", line 209, in <module>
upgrade2postgres()
File "/opt/wapt/waptserver/waptserver_upgrade.py", line 151, in upgrade2postgres
create_import_data(ip='127.0.0.1', fn=data_import_filename)
File "/opt/wapt/waptserver/waptserver_upgrade.py", line 72, in create_import_data
d = json.load(os.popen('mongoexport -h %s -d wapt -c hosts --jsonArray' % ip))
File "/usr/lib/python2.7/json/__init__.py", line 291, in load
**kw)
File "/usr/lib/python2.7/json/__init__.py", line 339, in loads
return _default_decoder.decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 364, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python2.7/json/decoder.py", line 382, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
File "/opt/wapt/waptserver/scripts/postconf.py", line 511, in <module>
main()
File "/opt/wapt/waptserver/scripts/postconf.py", line 338, in main
mongo_update_status = check_mongo2pgsql_upgrade_needed(waptserver_ini)
File "/opt/wapt/waptserver/scripts/postconf.py", line 241, in check_mongo2pgsql_upgrade_needed
run_verbose("sudo -u wapt /usr/bin/python /opt/wapt/waptserver/waptserver_upgrade.py upgrade2postgres")
File "/opt/wapt/waptserver/scripts/postconf.py", line 68, in run_verbose
output = subprocess.check_output(*args, shell=True, **kwargs)
File "/usr/lib/python2.7/subprocess.py", line 219, in check_output
subprocess.CalledProcessError: Command 'sudo -u wapt /usr/bin/python /opt/wapt/waptserver/waptserver_upgrade.py upgrade2postgres' returned non-zero exit status 1
Any idea what the problem might be?
Machine running Debian 9.*
THANKS !
Re: WAPT 1.3 to 1.5 Migration Error
Published: Dec 8, 2017 - 2:51 PM
by tech62
After running `apt-get install mongo-tools`, I get this:
could not change directory to "/root": Permission non accordée
2017-12-08T14:49:47.069+0100 connected to: 127.0.0.1
2017-12-08T14:49:47.138+0100 exported 6 records
WARNING:root:Traceback (most recent call last):
File "/opt/wapt/waptserver/waptserver_model.py", line 424, in update_host_data
existing = Hosts.select(Hosts.uuid, Hosts.computer_fqdn).where(Hosts.uuid == uuid).first()
File "/opt/wapt/lib/site-packages/peewee.py", line 4941, in select
query = SelectQuery(cls, *selection)
File "/opt/wapt/lib/site-packages/peewee.py", line 3016, in __init__
self.require_commit = self.database.commit_select
File "/opt/wapt/lib/site-packages/peewee.py", line 439, in __getattr__
raise AttributeError('Cannot use uninitialized Proxy.')
AttributeError: Cannot use uninitialized Proxy.
CRITICAL:root:Error updating data for [SERVERID] : AttributeError: Cannot use uninitialized Proxy.
main()
Published: Dec 8, 2017 - 3:10 PM
by tech62
By running: python /opt/wapt/waptserver/waptserver_upgrade.py upgrade2postgres
I get:
upgrading data from mongodb to postgresql
psql: FATAL: le rôle « root » n'existe pas
upgrade2postgres()
File "/opt/wapt/waptserver/waptserver_upgrade.py", line 144, in upgrade2postgres
val = subprocess.check_output(""" psql wapt -c " SELECT datname FROM pg_database WHERE datname='wapt'; " """, shell=True)
subprocess.CalledProcessError: Command ' psql wapt -c " SELECT datname FROM pg_database WHERE datname='wapt'; " ' returned non-zero exit status 2
Published: Dec 8, 2017 - 3:46 PM
by tech62
Postgres log:
déc. 08 15:10:27 wapt systemd[1]: Starting PostgreSQL RDBMS...
déc. 08 15:10:27 wapt systemd[1]: Started PostgreSQL RDBMS.
déc. 08 15:10:27 wapt systemd[1]: postgresql.service: Failed to reset devices.list: Operation not permitted
déc. 08 15:13:41 wapt systemd[1]: postgresql.service: Failed to reset devices.list: Operation not permitted
déc. 08 15:15:36 wapt systemd[1]: postgresql.service: Failed to reset devices.list: Operation not permitted
déc. 08 15:15:37 wapt systemd[1]: postgresql.service: Failed to reset devices.list: Operation not permitted
déc. 08 15:26:01 wapt systemd[1]: postgresql.service: Failed to reset devices.list: Operation not permitted
Published: December 8, 2017 - 5:20 PM
by sfonteneau
sudo -u wapt python /opt/wapt/waptserver/waptserver_upgrade.py upgrade2postgres
Published: Dec 8, 2017 - 5:27 PM
by tech62
Here is the result of the command:
Upgrading from mongodb to postgres
[uwsgi]
http-socket = 127.0.0.1:8080
master = true
processes = 16
wsgi=waptserver:app
chdir=/opt/wapt/waptserver/
max-requests=100
uid=wapt
gid=www-data
enable-threads = true
[options]
#################################mongodb_port=27017
#################################mongodb_ip=127.0.0.1
#wapt_folder=/var/www/wapt/
#waptwua_folder=/var/www/waptwua
#waptserver_port=8080
wapt_user=[SECRET]
wapt_password=[SECRET]
wapt_folder = /var/www/wapt
server_uuid = [SECRET]
#loglevel=warning
#client_tasks_timeout=0.3
#client_connect_timeout=1
#client_read_timeout=10
dumping mongodb data in /tmp/waptupgrade_20171208-Dec:26:1512750374.json
Read mongo data from 127.0.0.1...
2017-12-08T17:26:14.064+0100 connected to: 127.0.0.1
2017-12-08T17:26:14.131+0100 exported 6 records
6 records read.
File /tmp/waptupgrade_20171208-Dec:26:1512750374.json done.
Loading /tmp/waptupgrade_20171208-Dec:26:1512750374.json
6 recs to load
CRITICAL:root:Error updating data for [SECRET] : AttributeError: Cannot use uninitialized Proxy.
Error for [SECRET] : AttributeError: Cannot use uninitialized Proxy.
File "/opt/wapt/waptserver/waptserver_upgrade.py", line 153, in upgrade2postgres
load_json(filenames=data_import_filename)
File "/opt/wapt/waptserver/waptserver_upgrade.py", line 106, in load_json
wapt_db.rollback()
Exception while loading data, please check current configuration
Published: Dec 11, 2017 - 3:40 PM
by tech62
UP
Published: Dec 12, 2017 - 09:49
by htouvet
A database initialization is missing from the waptserver_upgrade code.
2 lines to add:
Add
from waptserver_model import load_db_config
in the imports at the top of the code
Add
conf = waptserver_config.load_config(options.configfile)
After
(options, args) = parser.parse_args()
--- a/waptserver/waptserver_upgrade.py
+++ b/waptserver/waptserver_upgrade.py
@@ -48,6 +48,7 @@ sys.path.insert(0, os.path.join(wapt_root_dir, 'lib'))
sys.path.insert(0, os.path.join(wapt_root_dir, 'lib', 'site-packages'))
from waptserver_config import __version__
+from waptserver_model import load_db_config
import logging
import ConfigParser
@@ -196,6 +197,7 @@ if __name__ == '__main__':
help='test prefix for fqdn and uuid for load testing (for development only)')
+ conf = waptserver_config.load_config(options.configfile)
utils_set_devel_mode(options.devel)
if options.loglevel is not None:
Night build:
https://wapt.tranquil.it/wapt/nightly/w...-ef7b7b4b/
Published: Dec 12, 2017 - 10:26
by tech62
Thanks for the feedback!
When will the change be implemented in the warehouse?
Published: Dec 12, 2017 - 11:36
by htouvet
I have updated the RC 1.5 repository
