Page 1 of 1
[SOLVED] How to run a PowerShell script?
Published: Dec 11, 2017 - 2:57 PM
by olaplanche
I need to run a PowerShell script from a package (to remove unnecessary apps from Windows 10 after an upgrade).
I've found several forum posts about this, but they all handle it differently!
Is there a cleaner solution?
For your information:
- WAPT version installed: 1.3.13
- Server OS: Debian Jessie
Thank you
Re: Running a PowerShell script?
Published: Dec 13, 2017 - 12:31
by sfonteneau
use the run_powershell function
For example :
run_powershell('Get-AppxPackage -Name Microsoft.Windows.Cortana -AllUsers | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}')
It's the cleanest
Published: Dec 13, 2017 - 4:06 PM
by olaplanche
Hello and thank you for the reply.
I am currently testing with the following package:
run_powershell('Get-AppXPackage -User Administrateur | where-object {$_.name –notlike “*store*”} | Remove-AppxPackage')
run_powershell('Get-appxprovisionedpackage –online | where-object {$_.packagename –notlike “*store*”} | Remove-AppxProvisionedPackage -online')
run_powershell('Get-AppxPackage -AllUsers | where-object {$_.name –notlike “*store*”} | Remove-AppxPackage')
Only the middle command seems to work (no issues with a new user account). I can't find anything about the `run_powershell` function; is it possible to get feedback like in the PowerShell console? The Wapt console isn't reporting any errors, yet the apps aren't being removed from the administrator account!
THANKS
Published: Dec 14, 2017 - 1:51 PM
by olaplanche
Additional information:
I am using the x64 version of powershell and this could be due to limitations of it for the system account.
Published: October 18, 2018 - 1:07 PM
by olaplanche
I'm bringing this problem up again, as I still haven't solved it.
Quite a few things have changed in the meantime, namely:
- Installed WAPT version: 1.6.2.7
- Server OS: Debian Stetch
- Operating system of the administration/package creation machine: Windows 10
Next, I use a new script during my MDT deployment; here it is:
# Functions
function Write-LogEntry {
param(
[parameter(Mandatory=$true, HelpMessage="Value added to the RemovedApps.log file.")]
[ValidateNotNullOrEmpty()]
[string]$Value,
[parameter(Mandatory=$false, HelpMessage="Name of the log file that the entry will written to.")]
[string]$FileName = "RemovedApps.log"
# Determine log file location
$LogFilePath = Join-Path -Path $env:windir -ChildPath "Temp\$($FileName)"
# Add value to log file
try {
Add-Content -Value $Value -LiteralPath $LogFilePath -ErrorAction Stop
catch [System.Exception] {
Write-Warning -Message "Unable to append log entry to RemovedApps.log file"
# Get a list of all apps
Write-LogEntry -Value "Starting built-in AppxPackage and AppxProvisioningPackage removal process"
$AppArrayList = Get-AppxPackage -PackageTypeFilter Bundle -AllUsers | Select-Object -Property Name, PackageFullName | Sort-Object -Property Name
# White list of appx packages to keep installed
$WhiteListedApps = @(
"Microsoft.DesktopAppInstaller",
"Microsoft.WindowsCalculator",
"Microsoft.WindowsStore"
# Loop through the list of appx packages
foreach ($App in $AppArrayList) {
# If application name not in appx package white list, remove AppxPackage and AppxProvisioningPackage
if (($App.Name -in $WhiteListedApps)) {
Write-LogEntry -Value "Skipping excluded application package: $($App.Name)"
else {
# Gather package names
$AppPackageFullName = Get-AppxPackage -Name $App.Name | Select-Object -ExpandProperty PackageFullName
$AppProvisioningPackageName = Get-AppxProvisionedPackage -Online | Where-Object { $_.DisplayName -like $App.Name } | Select-Object -ExpandProperty PackageName
# Attempt to remove AppxPackage
if ($AppPackageFullName -ne $null) {
try {
Write-LogEntry -Value "Removing application package: $($App.Name)"
Remove-AppxPackage -Package $AppPackageFullName -ErrorAction Stop | Out-Null
Write-LogEntry -Value "Removing AppxPackage failed: $($_.Exception.Message)"
else {
Write-LogEntry -Value "Unable to locate AppxPackage for app: $($App.Name)"
# Attempt to remove AppxProvisioningPackage
if ($AppProvisioningPackageName -ne $null) {
try {
Write-LogEntry -Value "Removing application provisioning package: $($AppProvisioningPackageName)"
Remove-AppxProvisionedPackage -PackageName $AppProvisioningPackageName -Online -ErrorAction Stop | Out-Null
Write-LogEntry -Value "Removing AppxProvisioningPackage failed: $($_.Exception.Message)"
else {
Write-LogEntry -Value "Unable to locate AppxProvisioningPackage for app: $($App.Name)"
# White list of Features On Demand V2 packages
Write-LogEntry -Value "Starting Features on Demand V2 removal process"
$WhiteListOnDemand = "NetFX3|Language|Browser.InternetExplorer"
# Get Features On Demand that should be removed
$OnDemandFeatures = Get-WindowsCapability -Online | Where-Object { $_.Name -notmatch $WhiteListOnDemand -and $_.State -like "Installed"} | Select-Object -ExpandProperty Name
foreach ($Feature in $OnDemandFeatures) {
try {
Write-LogEntry -Value "Removing Feature on Demand V2 package: $($Feature)"
Get-WindowsCapability -Online -ErrorAction Stop | Where-Object { $_.Name -like $Feature } | Remove-WindowsCapability -Online -ErrorAction Stop | Out-Null
Write-LogEntry -Value "Removing Feature on Demand V2 package failed: $($_.Exception.Message)"
# Complete
Write-LogEntry -Value "Completed built-in AppxPackage and AppxProvisioningPackage removal process"
I would like to use it in a wapt package, but I don't see how...
Can someone point me in the right direction?
THANKS
Published: Dec 19, 2018 - 10:12
by olaplanche
I solved my problem with the following code:
#import subprocess
run('powershell.exe -NoProfile -NonInteractive -File RemoveBuiltinApps.ps1')
You need to enable PowerShell script execution on the affected machines or add the "-executionpolicy bypass" parameter
Re: [SOLVED] Run a PowerShell script?
Published: October 15, 2019 - 11:45 AM
by jeancharles
A bit late, but wouldn't it be better to modify the powershell command to add "-executionpolicy bypass" directly into the command?
Published: October 15, 2019 - 12:00 PM
by olaplanche
That's exactly what I indicated in my sentence
You need to enable PowerShell script execution on the affected machines or add the "-executionpolicy bypass" parameter.
Published: October 15, 2019 - 12:04 PM
by jeancharles
Ah yes, indeed, reading about it, that's it,
I'm trying to go too fast and I'm forgetting half the information along the way!
Thank you!
