No installation required when the workstations are switched off
Published: January 9, 2018 - 12:09 PM
Hello and Happy New Year to all,
I've noticed that on one of the domains I manage, the workstations aren't applying the update on shutdown. I must have made a mistake during deployment, but since it was a while ago, I can't figure out where the problem lies.
The domain runs on Windows 7 Pro with a Linux server (no GPO). WAPT is installed on my machine. The agent was deployed using PsTools, and manual installations work correctly.
I tried using the command `wapt-get add-upgrade-shutdown`, which returns "none" on one client and "FATAL ERROR: IndexError: list index out of range" on the machine hosting the WAPT server.
Is there a command I can add to a WAPT package to force this setting or reinstall the `wapt-exit` service?
