Page 1 of 1
Installing Wapt 1.5 under Centos
Published: January 18, 2018 - 11:03 AM
by hasop
I installed Wapt for the first time on CentOS.
I believe I followed the installation documentation for this system to the letter.
Everything went smoothly until the Windows console installation step (https://www.wapt.fr/wapt-1.5/Configuration/index.html).
Indeed, there is no .exe file in the specified path.
During my tests with a Windows server, I remember generating the files directly from the Windows console. What about with a Linux server? Did I miss a step in the documentation?
Re: Installing Wapt 1.5 under Centos
Published: January 18, 2018 - 2:30 PM
by sfonteneau
There is a small error in the document:
missing:
yum install tis-waptsetup
Published: January 18, 2018 - 2:37 PM
by hasop
That definitely changes everything!
Thank you
Published: January 18, 2018 - 4:29 PM
by hasop
I managed to install the console with its various certificates (it wasn't the easiest thing).
During the wapt-setup installation, I got the message in a console:
"Please get login for add_host:"
I must have responded incorrectly, because it moved on to something else, but my PC isn't visible.
So I launched the register from the command line using my admin username and password, but it doesn't seem to be what's expected:
C:\Windows\system32>wapt-get register
Please get login for add_host:admin
Password:
FATAL ERROR: HTTPError: 401 Client Error: Unauthorized for url: https://xxxx/add_host
Any ideas?
Published: January 18, 2018 - 9:55 PM
by sfonteneau
Do you want to configure workstation authentication?
Kerberos or strong authentication.
when you launch:
python /opt/wapt/waptserver/scripts/postconf.py
One step offers you Waptagent authentication type.
To activate "without authentication", this is the first option
To activate Kerberos, it's the second option
To enable ID/password authentication, it's the 3rd option
Depending on the choice, the agent will ask:
- 1 nothing
- 2. Nothing if the workstation is in the domain and the WAPT server is correctly configured for Kerberos
- 3. The username and password for the wapt console
Published: January 19, 2018 - 09:03
by hasop
Option 2, but I only have two choices:
- Allow unauthenticated registration
- Require strong authentication...
Does this mean the Kerberos installation is faulty?
How can I check?
Published: January 19, 2018 - 09:47
by sfonteneau
hasop wrote: ↑Jan 19, 2018 - 09:03 Option 2, but I only have 2 choices:
Does this mean the Kerberos installation isn't working correctly?
How can I check?
Indeed, Kerberos authentication does not seem to be working correctly.
Is the position in the right field?
Published: January 19, 2018 - 09:52
by hasop
Normally, yes.
I just noticed that after restarting the post-installation, the "use_kerberos" parameter reverted to False.
Setting it back to True doesn't change anything, however.
Since this is an experiment, I'm going to try disabling Kerberos everywhere and switching to a basic mode.
(EDIT after some experimentation) => Registration works correctly with the following server options in waptserver.ini:
use_kerberos = False
allow_unauthenticated_registration = True
Published: March 9, 2018 - 12:14
by benoitpatin
I have the same problem.
I restarted my server configuration and selected option 2, then rebooted.
I reinstalled the client on a machine that is in the domain, but I still get the "add_host" prompt.
