Lo mismo, pero forzado:
Installing ***-windows11-upgrade(=10.0.22621-98)
Free disk space: 188838961152 bytes
C:\WindowsUpgrade folder exists, continuing...
Force Upgrading Windows from version: 10.0.19044 to Windows 11 version: 10.0.22621
Erreur lors de l'installation de ['***-windows11-upgrade']: erreurs dans les paquets [[PackageRequest(package='***-windows11-upgrade',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19044.2'),max_os_version=Version('10.0.19044.2')), PackageEntry('***-windows11-upgrade','10.0.22621-98' architecture='x64',maturity='PROD',locale='fr',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Windows\\TEMP\\wapt18wdbmnj\\setup.py", line 66, in install\n File "C:\\Program Files (x86)\\wapt\\common.py", line 3840, in run\n return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2138, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"C:\\\\WindowsUpgrade\\\\setup.exe" /auto upgrade /quiet /eula accept /telemetry disable /showoobe none /dynamicupdate enable /copylogs "C:\\\\WindowsUpgradeLogs\\\\win11_force_upgrade_logs"\' returned non-zero exit status 1.\nOutput:\'"C:\\WindowsUpgrade\\setup.exe"\' n\'est pas reconnu en tant que commande interne\r\nou externe, un programme exécutable ou un fichier de commandes.\r\n\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5186, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4156, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4063, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\wapt18wdbmnj\\setup.py", line 72, in install\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1913, in error\n raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : Command \'"C:\\\\WindowsUpgrade\\\\setup.exe" /auto upgrade /quiet /eula accept /telemetry disable /showoobe none /dynamicupdate enable /copylogs "C:\\\\WindowsUpgradeLogs\\\\win11_force_upgrade_logs"\' returned non-zero exit status 1.\nOutput:\'"C:\\WindowsUpgrade\\setup.exe"\' n\'est pas reconnu en tant que commande interne\r\nou externe, un programme exécutable ou un fichier de commandes.\r\n\n']]
- ¿Existe una versión mínima de Windows 10 requerida para la actualización (estoy en 21H2)?
- ¿Qué pasa con los requisitos previos de Knowledge Base validados desde mis repositorios de Windows Update de WAPT?
-¿Una cuestión de derechos?
Gracias, Thomas.
