Error en el análisis de Windows Update
t.heroult
Inscripción: 8 de diciembre de 2020 - 10:13 a. m.
21 de febrero de 2023 - 15:55
Buen día
En un servidor, cuando ejecuto el análisis de actualización, obtengo este error después de un minuto:
Ensure wuauserv Auto Update option is disabled
Scanning with windows updates rules:
 "direct_download":false,
 "default_allow":false,
 "include_potentially_superseded_updates":false,
 "filter":"Type='Software' or Type='Driver'",
 "download_scheduling":"None",
 "install_scheduling":"None",
 "install_delay":"None",
 "postboot_delay":"10m"
Looking for updates with filter: Type='Software' or Type='Driver'
   Connecting to local update searcher using offline wsusscn2 file...
re-enabling wuauserv previous state: 2
(-2147352567, 'Une exception s’est produite.', (0, None, None, None, 0, -2145124303), None)
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1907, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 710, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\enterprise.py", line 216, in _run
    self.result = wua.scan_updates_status(self.force)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 914, in scan_updates_status
    for update in self.updates():
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 822, in updates
    search_job = self.update_searcher().BeginSearch(self.params.filter, scb_interface, None)
  File "C:\Program Files (x86)\wapt\waptwua\client.py", line 784, in update_searcher
    self._update_service = self.update_service_manager().AddScanPackageService("Offline Sync Service", self.wsusscn2)
  File "C:\Windows\TEMP\gen_py\3.8\B596CC9F-56E5-419E-A622-E01BB457431Ex0x2x0\IUpdateServiceManager2.py", line 36, in AddScanPackageService
    ret = self._oleobj_.InvokeTypes(1610743814, LCID, 1, (9, 0), ((8, 1), (8, 1), (3, 49)),serviceName
pywintypes.com_error: (-2147352567, 'Une exception s’est produite.', (0, None, None, None, 0, -2145124303), None)
0x80020009 (Une exception s’est produite.): 0x80240031 ((unable to get meaning for error code 0x80240031))
    self._run()
¿Alguna idea?
Atentamente,
Tomás
Consolas: Windows 10 y 11
Infraestructura: Windows
21 de febrero de 2023 - 18:17
Buenas noches,
El error correspondería a "Uno o más componentes de Windows Update en el registro pueden estar dañados, corruptos o faltantes"
la orden
sfc /scannow
Ejecutar el comando en un símbolo del sistema de administrador con privilegios elevados puede ayudar a resolver el problema.
TI tranquila
dcardón
24 de febrero de 2023 - 14:21
Hola Thomas,
¿ejecutar sfc /scannow solucionó el problema en la máquina? (Así podemos cerrar el hilo)
t.heroult
2 de marzo de 2023 - 14:29
No puedo probarlo ahora mismo; el servidor está esperando a reiniciarse y el comando `sfc /scannow` está esperando a que finalice el reinicio antes de ejecutarse.
Puede que tarde un rato...
