tis-java8 / Estado de ERROR
Respuesta
Aramis
Inscripción: 16 de julio de 2024 - 11:48
1 de agosto de 2024 - 14:24
Estoy usando WAPT Enterprise versión 2.5.5.15691 en un servidor Debian 12.6 (6.1.94-1 (2024-06-21)).
Intenté implementar el paquete tis-java8 en estaciones de trabajo a través de una unidad organizativa de AD.
Me sale el siguiente error:
Installing: drsilil-java8
WARNING: A Java Runtime Environment 8 (JRE) will be installed with WAPT since this package allow arbitrary install based on available package in a specific order
Erreur lors de l'installation de ['drsilil-java8(=10.0-2)']: erreurs dans les paquets [[PackageRequest(package='drsilil-java8',version=(Version('10.0.0.0'), 2),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('drsilil-java8','10.0-2' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\WINDOWS\\TEMP\\waptj_8j0rpe\\setup.py", line 35, in install\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1957, in error\n    raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : ERROR: No Java Runtime Environment 8 (JRE) have been deployed on this system, please import and deploy the package adapted to your organization\n']]
  File "<string>", line 1939, in run
    self._run()
Exception: Erreur lors de l'installation de ['drsilil-java8(=10.0-2)']: erreurs dans les paquets [[PackageRequest(package='drsilil-java8',version=(Version('10.0.0.0'), 2),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('drsilil-java8','10.0-2' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\WINDOWS\\TEMP\\waptj_8j0rpe\\setup.py", line 35, in install\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1957, in error\n    raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : ERROR: No Java Runtime Environment 8 (JRE) have been deployed on this system, please import and deploy the package adapted to your organization\n']]
    self._run()
Entonces, pienso que esta no es la versión adaptada correcta.
Elimino el paquete de la lista de paquetes que se instalarán en esta OU.
Constantemente he tenido un error en el estado de cada máquina.
Así que probé el paquete wapt-forget-packages especificando correctamente el paquete tis-java8, pero sin éxito ya que este paquete finalmente no está instalado en las máquinas.
El error persiste en la consola con un estado de error para cada máquina.
Consultando el foro, el consejo que se da es utilizar el comando "olvidar el paquete".
Pero este comando no está disponible cuando selecciono una máquina.
¿Cómo puedo restaurar el estado de cada máquina y eliminar permanentemente la instalación de este paquete?
Gracias por cualquier consejo que puedas brindarme.
Atentamente,
14 de agosto de 2024 - 13:25
El paquete tis-java8 es bastante específico.
Intenta instalar uno de los siguientes paquetes:
tis-adoptium-openjdk8-jre,
tis-oracle-java8-jre-free
o tis-oracle-java8-jre-nonfree.
Por lo tanto, su repositorio debe contener al menos uno de estos tres paquetes.
Dependiendo de sus necesidades de uso de Java, usted decide cuál desea.
Respuesta
