Me pongo en contacto con usted porque tengo problemas para crear un paquete de Windows Movie Maker 2012.
Aquí está mi archivo setup.py para este paquete:
print('installing uvhc-windowsmoviemaker')
run(r'"wlsetup-all.exe" /AppSelect:MovieMaker /noMu /noHomePage /noSearch /noLaunch /noToolBarCEIP /q')
#Modification clé de registre pour les accord EULA
run('REG ADD "HKEY_CURRENT_USER\Software\Microsoft\Windows Live\Common" /v TOUVersion /t REG_SZ /d "16.0.0.0" /f ')
installing uvhc-windowsmoviemaker2012
2016-02-19 11:57:25,375 CRITICAL Fatal error in install script: CalledProcessError: Command '('"wlsetup-all.exe" /AppSelect:MovieMaker /noMu /noHomePage /noSearch /noLaunch /noToolBarCEIP /q',)' returned non-zero exit status -2147219456:Traceback (most recent call last):
File "C:\wapt\common.py", line 3266, in install_wapt
File "c:\windows\temp\waptncksv3\setup.py", line 25, in install
File "C:\wapt\common.py", line 3113, in run
return setuphelpers.run(*arg,pidlist=self.pidlist,**args)
File "C:\wapt\setuphelpers.py", line 959, in run
raise subprocess.CalledProcessError(proc.returncode,cmd,''.join(output))
2016-02-19 11:57:25,510 CRITICAL Package uvhc-windowsmoviemaker2012 (=16.4.3528.331-10) not installed due to errors : CalledProcessError: Command '('"wlsetup-all.exe" /AppSelect:MovieMaker /noMu /noHomePage /noSearch /noLaunch /noToolBarCEIP /q',)' returned non-zero exit status -2147219456
2016-02-19 11:57:25,513 CRITICAL Exception: Erreur lors de l'installation de uvhc-windowsmoviemaker2012 (=16.4.3528.331-10) : {'skipped': [], 'additional': [], 'downloads': {'downloaded': [u'C:\\wapt\\cache\\uvhc-windowsmoviemaker2012_16.4.3528.331-10_all.wapt'], 'skipped': [], 'errors': []}, 'remove': [], 'upgrade': [], 'install': [(u'uvhc-windowsmoviemaker2012 (=16.4.3528.331-10)', PackageEntry('uvhc-windowsmoviemaker2012','16.4.3528.331-10'))], 'errors': [[u'uvhc-windowsmoviemaker2012 (=16.4.3528.331-10)', PackageEntry('uvhc-windowsmoviemaker2012','16.4.3528.331-10')]], 'unavailable': []}
Además, al ejecutar el comando de instalación silenciosa desde el símbolo del sistema clásico de Windows, el programa se instala correctamente.
¿Alguien tiene alguna idea de cómo sacarme del atolladero?
Gracias de antemano.
Lucas
