Re: Instalación avanzada de *.exe
Publicado: 25 de abril de 2018 - 13:13
@htouvet,
¡¡¡Muchas gracias por toda vuestra ayuda!!!
A continuación la versión final del script de Instalación y Desinstalación completa del Miktex 2.9 software.
destdir = makepath(programfiles,'MIKTEX')
startupdir = makepath(start_menu(1),"Programs","MiKTeX 2.9")
print('Initializing installation of miktex.')
mkdirs(destdir)
install_exe_if_needed("basic-miktex-2.9.6643-x64.exe", timeout=2000, silentflags='--shared --unattended --common-install="%s"' % destdir)
print('Installation OK!')
try:
print('Starting update miktex...')
run(r'"%s"\miktex\bin\x64\mpm.exe --update --admin' % destdir, timeout=2000)
print('Updated miktex OK!')
except (RuntimeError, TypeError, NameError):
raise
try:
print('Starting miktex uninstall...')
if iswin64():
print('Uninstalling x64 version')
run(r'"%s"\miktex\bin\x64\miktexsetup.exe --verbose --shared uninstall' % destdir, timeout=2000)
remove_tree(destdir)
print("%s" ' is removed successfully!' % destdir)
remove_tree(startupdir)
print("%s" ' is removed successfully!' % startupdir)
print('Uninstalling x86 version')
print('Uninstallation of miktex completed!')
raise
