Página 1 de 1
Migración: no se encontró mongoexport
Publicado: 30 de marzo de 2018 - 16:33
por Floflobel
Tengo un problema al intentar actualizar Wapt a la última versión. Al intentar migrar la base de datos, recibo este mensaje de error:
mongodb process running, need to migrate
could not change directory to "/root": Permission denied
/bin/sh: 1: mongoexport: not found
  File "/opt/wapt/waptserver/waptserver_upgrade.py", line 191, in <module>
    upgrade2postgres()
  File "/opt/wapt/waptserver/waptserver_upgrade.py", line 152, in upgrade2postgres
    jsondata = create_import_data()
  File "/opt/wapt/waptserver/waptserver_upgrade.py", line 70, in create_import_data
    if 'dbpath' in subprocess.check_output('mongoexport --help',shell=True):
  File "/usr/lib/python2.7/subprocess.py", line 219, in check_output
subprocess.CalledProcessError: Command 'mongoexport --help' returned non-zero exit status 127
  File "/opt/wapt/waptserver/scripts/postconf.py", line 486, in <module>
    main()
  File "/opt/wapt/waptserver/scripts/postconf.py", line 473, in main
    upgrade2postgres(options.configfile)
  File "/opt/wapt/waptserver/scripts/postconf.py", line 236, in upgrade2postgres
    run_verbose('sudo -u wapt PYTHONPATH=/opt/wapt PYTHONHOME=/opt/wapt /opt/wapt/bin/python /opt/wapt/waptserver/waptserver_upgrade.py upgrade2postgres -c "%s"' % configfilename)
  File "/opt/wapt/waptserver/scripts/postconf.py", line 66, in run_verbose
    output = subprocess.check_output(*args, shell=True, **kwargs)
subprocess.CalledProcessError: Command 'sudo -u wapt PYTHONPATH=/opt/wapt PYTHONHOME=/opt/wapt /opt/wapt/bin/python /opt/wapt/waptserver/waptserver_upgrade.py upgrade2postgres -c "/opt/wapt/conf/waptserver.ini"' returned non-zero exit status 1
Re: Migración: no se encontró mongoexport
Publicado: 30 de marzo de 2018 - 16:43
por Floflobel
Problema resuelto instalando mongo-tools
