Página 1 de 3
[RESUELTO] Paquete eliminar aplicaciones metro
Publicado: 14 de julio de 2019 - 10:18 a. m.
por Mathieu
Últimamente he tenido un problema con un paquete de aplicaciones de "Eliminar Metro". Antes funcionaba perfectamente, pero después de varias instalaciones, el paquete muestra un error, aunque no he modificado el script desde que se puso en producción
Aquí está el mensaje:
Starting the debloating process...Trying to remove Microsoft.BingFinance
NoneTrying to remove Microsoft.BingNews
NoneTrying to remove Microsoft.BingSports
NoneTrying to remove Microsoft.BingWeather
NoneTrying to remove Microsoft.Getstarted
NoneTrying to remove Microsoft.XboxApp
NoneTrying to remove Microsoft.ZuneMusic
NoneTrying to remove Microsoft.ZuneVideo
NoneTrying to remove Microsoft.MinecraftUWP
NoneTrying to remove Microsoft.BingFoodAndDrink
NoneTrying to remove Microsoft.BingTravel
NoneTrying to remove Microsoft.BingHealthAndFitness
NoneTrying to remove Microsoft.WindowsReadingList
NoneTrying to remove Flipboard.Flipboard
NoneTrying to remove ShazamEntertainmentLtd.Shazam
NoneTrying to remove king.com.CandyCrushSaga
NoneTrying to remove king.com.CandyCrushSodaSaga
NoneTrying to remove king.com.*
NoneTrying to remove ClearChannelRadioDigital.iHeartRadio
NoneTrying to remove 4DF9E0F8.Netflix
NoneTrying to remove 6Wunderkinder.Wunderlist
NoneTrying to remove Drawboard.DrawboardPDF
NoneTrying to remove 2FE3CB00.PicsArt-PhotoStudio
NoneTrying to remove D52A8D61.FarmVille2CountryEscape
NoneTrying to remove TuneIn.TuneInRadio
NoneTrying to remove TheNewYorkTimes.NYTCrossword
NoneTrying to remove 828B5831.HiddenCityMysteryofShadow
NoneTrying to remove Microsoft.Advertising.Xaml
NonePreviously removed by wapt :
Remaining metro apps ;) : Traceback (most recent call last):
  File "C:\Program Files (x86)\wapt\common.py", line 3846, in install_wapt
  File "c:\windows\temp\waptxq1txp\setup.py", line 102, in install
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 4399, in run_powershell
    raise ValueError(u'%s returned non json data:\n%s' % (cmd,result))
UnicodeDecodeError: 'ascii' codec can't decode byte 0x8a in position 47313: ordinal not in range(128)
'ascii' codec can't decode byte 0x8a in position 47313: ordinal not in range(128) : faulty string is ''[\r\n    {\r\n        "Name":  "1527c705-839a-4832-9118-54d4Bd6a0c89",\r\n        "Publisher":  "CN=Microsoft Windows, O=Microsoft Corporation, L=Redmond, S=Washington, C=US",\r\n        "PublisherId":  "cw5n1h2txyewy",\r\n        "Architecture":  11,\r\n        "ResourceId":  "neutral",\r\n        "Version":  "10.0.16299.15",\r\n        "PackageFamilyName":  "1527c705-839a-4832-9118-54d4Bd6a0c89_cw5n1h2txyewy",\r\n        "PackageFullName":  "1527c705-839a-4832-9118-54d4Bd6a0c89_10.0.16299.15_neutral_neutral_cw5n1h2txyewy",\r\n        "InstallLocation":  "C:\\\\Windows\\\\SystemApps\\\\Microsoft.Windows.FilePicker_cw5n1h2txyewy",\r\n        "IsFramework":  false,\r\n        "PackageUserInformation":  [\r\n                                       "S-1-5-21-485133025-386941804-4221807023-500 [Administrateur]: Installed",\r\n
Tuve que cortarlo, pero continúa con todas las aplicaciones que están en el script.
No entiendo por qué de repente el script empezó a funcionar mal.
Gracias por su ayuda
Re: Paquete eliminar aplicaciones metro
Publicado: 19 de julio de 2019 - 19:08
por dcardon
Hola Mathieu,
Mathieu escribió: 14 de julio de 2019 - 10:18 AM Recientemente he tenido un problema con un paquete Remove Metro apps. Solía ​​funcionar perfectamente, pero después de algunas instalaciones, el paquete muestra un error, aunque no he tocado el script desde que el paquete se puso en producción.
¿Qué versión de WAPT, qué versión del sistema operativo?
Mathieu escribió: 14 de julio de 2019 - 10:18 Aquí está el mensaje:
Las máquinas también tienen sus cambios de humor, sus pequeñas peculiaridades, etc. Cada actualización de Windows puede ser una oportunidad para descubrir nuevos comportamientos y nuevas anomalías :-) .
En este caso, el script de PowerShell devuelve un archivo JSON con una codificación inesperada. Parece que el blob JSON debe haberse truncado, ¿verdad?
Atentamente,
Denis Cardón
Publicado: 22 de julio de 2019 - 14:10
por Mathieu
Disculpen, olvidé mencionarlo
: WAPT 1.7.4.6143 Enterprise
- Debian 9.9.
Todas nuestras máquinas tienen la misma versión de Windows 10, 1709.
Las actualizaciones se implementan a través de WSUS, así que, en lo que respecta al sistema operativo, las máquinas son idénticas.
Respecto al "JSON Blob", no sé nada al respecto; no lo he tocado.
Publicado: 25 de julio de 2019 - 11:12 a. m.
por htouvet
Sería interesante ver qué está mal con la versión de PowerShell...
en el paquete al final del procedimiento install()
reemplazar
    print(u'Remaining metro apps ;) : ')
    print(u'\n'.join(sorted(u'"%(Name)s", # (%(Version)s)",' % app for app in run_powershell('Get-AppxPackage -AllUsers'))))
por
    print(repr(run_powershell('Get-AppxPackage -AllUsers',output_format='txt')))
¿Puedes publicar el resultado de una instalación en una máquina donde está causando problemas?
Publicado: 30 de julio de 2019 - 17:46
por Mathieu
Creo que hubo un problema; reemplacé las líneas correctamente
  File "c:\waptdev\futur-OptionW10_remove_metroapps_PROD-wapt\setup.py", line 104, in install
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 4384, in run_powershell
    raise CalledProcessErrorOutput(e.returncode,cmd,e.output)
CalledProcessErrorOutput: Command u'Get-AppxPackage -AllUsers' returned non-zero exit status -196608.
Output:?????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
FATAL ERROR : CalledProcessErrorOutput: Command u'Get-AppxPackage -AllUsers' returned non-zero exit status -196608.
Output:…ù?‘«?‘?ú†?ý‘?ù‘ñªƒû?‡­¾†æ¾†ªÿ†?ð„??‘ûî‘«ü‘?ª‘¾?‘?ªÆøÿ‘¾Ý‘­œ‘?¸Æûý‡øÿƒïÿ‘??‡?ý‘«¸ƒ?©‡?¬‡?¾‘¾ü‘ûî†ïó…ù?ƒ?ÿƒ?ÿƒæ?‘«?‘«?‘«õƒ??ƒæ?‘«?‡­?‡?¸ƒ??ƒæ?‡??†æ­ƒæ?‡??†æ­†ªÿ„÷ð†?î‘«ý‘¾Ý‘?ªƒ??ƒæ?‘«?„¾©‡?©‡?¾‘?­‘¾ï‘?ô…æ?ƒ??ƒ?ÿ†ªÿ„Ïð‡?©‡?æ‘«?‘æý‡?­‡ªÿ‘??‡?÷‡øÿ†ÿÿ„ñ?†æ«†ªÿ„¬ð‡?æ‡?ø„?ï‡?î‘?ðƒ?ï†?¯‡­¾ƒ?ïƒ?¬„æ?‡æ?…æ?ƒ??ƒ?ÿ†ªÿ†?ð‘û¸‘«Ï†?ú‡¾ï‘?ªÆøÿ‡?ü‘ñûÆû¾ƒ??ƒæ?‘û?‘«œ‘?Ï„?Ï‘æî‘?ð‘?©Æøÿ‘«Ÿ‘æð‘û­‘?Ï‘?ÿ‘?î‘??‘?ÿƒ?©‘?½‘?üÆ?ÿÆ÷ï…æ?ƒ??ƒ?ÿ†ªÿ„?ð‘û݇?õ‘?ý‘¾ï‘ûî‘??‘?ðÆøÿ‘­œŠñ­‘?©†ïó…ù?ƒ?ÿƒ?ÿƒæ?‘¾?‘?ªÆøÿ‘­œ‘澑û¸‘?ÿ‘?õ‘?œ‡??‘?ÿƒ?摾ݑ­œ‘?¸ÆûýÆøÿ‡?­‡?õ‘?ð‡?©Æûüƒ??ƒæ?‡­?‘?¾‡?æ‘«¸†?©‘ñî‘?¸ƒ?û†?¬‡?ï‡?­‘??‘?¸‘?ÿ‘?õŠ?÷‡?œ‘¾ï‘ûî†ïó…ù?ƒ?ÿƒ?ÿƒæ?‘«Ÿ‘æð‘û­ƒ?σ?¯ƒ?ðƒ?¬‘?¬‘«ªƒ?œ‘?χ?ÿ‡?œ‡?¸Æûÿ‘?ð‘?ýƒ?ü‡?¬‘?­‘?ª‡?­‘?ÿ‘?õ‘?ý‘ææ‘û¾‡?ï†ïó…ù?ƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?¬‘?¬‘?ù‘§?Æû¾†ªÿ†?¬‡?­‘æ­‡??‘?ýƒ?ü‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?φïó‡ïÿ†ïÿ…ù?…ù?‘«?‘?ú†?ý‘?ù‘ñªƒû?‡­¾†æ¾ƒïÿ‘??‡?ª‡øÿƒïÿƒ?¨ƒ?¬Æ¬î…ù?…ù?†?ð„??‘ûî‘«ü‘?ª‘¾?‘?ª…ù?ƒ?ÿƒ?ÿ‘­Ÿ‡?­‘?õ‘øÿƒ?¾‘¾Ý‘­œ‘?¸ƒ?ý‘?Ï‘?ÿ‘ûî‘«ü‘?ª†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª‡?ü‘??‘?¸Š?¸ƒ?©‘«?‡?æ‘?ÿŠ?ý‡?¾‡?ÿ…橃??ƒ?ÿ‘?ÿ‘?¸‘¾ù‡?¾‘?ÿƒ?¾‘«œ‡?©‘ñîƒñ¾‡?ÿ‘¾ï‘¾ª‘?üƒ?§‡­?‘«ø‡?ý„?ð‘ûî‘«ü‘?ª‘?ÿ‘û­ƒ?ü‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…ï©…ï?ƒï?‘??‡?ý‘«¸…橃??ƒ?ÿ„?ÿ‘ô?‡?­‘?ý‘øÿƒ?­‘?ô‡?ý‘«¸ƒ?©‡?ü‘??‘?¸Š?¸ƒ?¾‘?φ?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒûª…ïÿƒ??ƒ?ÿ„?ÿ‡?©‘?ýƒ?§‘ûæ‘÷ÿ‘ææ‡??ƒ?î‘?χ?ÿ‡?¾‘¾ü‘ûî‘?ÿ‘?ôƒ?œ‘?ª‡?ÿ‡?­‘æ­‡??‘?ýƒ?ª‘?ïƒ?ª‡?ñƒ?¾ƒ?©‡?ð‡?¾‘¾ü‘ûîÆ?ÿÆ?©ˆ¬ÿ…ï©…ï?ƒï?‘«?‘«?‘«õ…ù?ƒ?ÿƒ?ÿ‘??‡?ü‘?æ‘øÿƒ?­‘?½‘û©Š¸¸‘?ý‘?ÿƒ?¾‘«œ‡¾ø‘¾ý‘­õƒ?ï‡?­‘?ÿ‘ô?‡?­‘?ý‘?õ…ï©…ï?ƒï?‘«?‡­?‡?¸…ù?ƒ?ÿƒ?ÿ‘??‡?ÿƒ?¾‘?Ý‘æýƒ?¾‘?øƒ?ü‡?­Š¸ýƒ?üƒ?ª‡­¾‘??‡?æ‘«¸ƒ?©‘?σ?ü‘«œ‘æð‘û­‘?σ?ü‘?Ï‘?ÿ‘ô?‡?­‘?ý‘?õ…ï©…ï?ƒï?‡??…æ­ƒ??ƒ?ÿ„?ÿ‘ô?‡?­‘?ý‘øÿ‘Ïõ‡?©‡?¾‡?ø‡??‡?¾ƒ?ý‘?Ï‘?ÿ‘æî‘?ð‘?©‡?¾Š?ÿ‘øÿ‘?õ‘?¸ƒ?¾ƒ?Ï‘ûæ‘?ÿ‘«ª‡?¸‘ûî‘?©‘?ð‡?©‘ïÿ‘ûî‡?î‡?ù‘?¾ƒûÏ…ù?ƒ?ÿƒ?ÿ‘??‘?ÿ‘«ª‡?¸‘ûî‘?©‘?ð‡?©‘ïÿ‘ûî‡?î‡?ù‘?¾ƒ?φ?ù„??ƒ?¸‡?¾ƒ?ï‡?æ‘ñ¸‡?¸ƒ??‘?øƒ?ýŠ?Ï‘?݇?æ…ï©…ï?ƒï?‡??…æ­ƒ??ƒ?ÿ„?ÿ‘ô?‡?­‘?ýƒ?ýƒ?ª‘û¸‘?ï‡?ýŠ?ý‘?ï‡?æ‘?ÿƒ?¾‘«œ‘æð‘û­‘?σ?üƒ??ƒ?ª‘¾­‘?Ï‘?ÿ‡?õƒ?©‘ñœ‘¾î‘«ü‘û©‘澑û¾ƒ?ï‡?ð‡?ª‡?¸‡?ù‘?¾ƒûÏ…ù?…ù?„÷ð†?î‘«ý‘¾Ý‘?ª…ù?ƒ?ÿƒ?ÿ‘??‘?ÿ‘?ù‘?ýƒ?¾‘?øƒ?ü‘?ª‡?ÿ‘«ý‘¾Ýƒ?ª‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…ï©…ï?ƒï?‘«?„¾©‡?©‡?¾‘?­‘¾ï‘?ô…ù?ƒ?ÿƒ?ÿƒ??‘?­‘¾Ý‘­œƒ?¾‘?øƒ?üƒ?Ï‘û¸‘¾ô‘?ï‘Ïÿ‡?©‡?¾‘?­‘¾ï‘?ô‡?ÿ‡?îƒ?ýƒ?ª‡?æ‘ñ¸‡?¸‡?­‡?¾ƒûý…ù?…ù?„Ïð‡?©‡?æ‘«?‘æý‡?­…ù?ƒ?ÿƒ?ÿŠ??‡?œ‡?¸‘øÿƒ?¾‘«Ý‘æý‡?­‘?ÿ‡?¾‘?ÿ‘ûîŠ?©‡?¾‘?ÿ‡?©‡¾î‘??ƒ?üƒ??‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñªƒ?©‘??ƒ?ü‘?ô‘?ª‡?æ…æüƒ??ƒ?ÿ‡?ÿ‘ñ­‘?¸‡?¾‡?ÿ‘ûîƒ?ïƒ?©‘??‡?÷ˆ¬ÿƒÿÿ‘­œŠñ­‘?©ƒ?ü‘?χ?ÿ‡­¾‘?ïƒ?¸‡?îˆ÷ÿ†ÿÿ„ñ?ˆ¬ÿƒÿÿ‘«Ý‘æý‡?­„?ÿ„¾?„æ?ƒ??Š?ü‘¾ý‘ñ­‡?¸ƒÝ?…ï©…ï?ƒï?‡??‡?ï‡?æ‘«?‘æý‡?­…ù?ƒ?ÿƒ?ÿŠ??‘?ï‘æý‘û¸ƒ?¾‘?ª‘ïÿ‡??‘«ù‘?Ï‘?ÿƒ?¾‘¾ð‘?ü‘?ÿƒ?©‘«Ý‘æýƒ?¾‘?Ï‘øÿƒ?­‘«ü‡?ý‘?¸‘?ÿƒ?¾‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…暑??ƒ?ÿ„øÿ‡?¾‡?ÿ‘ñ­‡?¾‡?ý‡?ÿ‘ñ­‘?¸‡?¾‡?ÿ‘ûîƒ?ïƒ?©‘??‡?÷ˆ¬ÿƒÿÿ‘­œŠñ­‘?©ƒ?ü‘?χ?ÿ‡­¾‘?ïƒ?¸‡?îˆ÷ÿ†ÿÿ„ñ?ˆ¬ÿƒÿÿ‘«Ý‘æý‡?­„?ÿ„¾?„æ?ƒ??Š?ü‘¾ý‘ñ­‡?¸ƒÝ?…ï©…ï?ƒï?‘¾?‘?©‡?î‡??‘ñû…澃??ƒ?ÿ„?ÿ‘??‘û¸‡?¸‘øÿƒ?¾‡?ü‘ñûƒ?¾‘?Ï‘?ÿ‘û¾‡??‘?ý‡?ÿ‡?æ„÷ÿ‡?î‘?ðƒñª„ïÿ‘û¸‘渇¸¸‘?¾ƒ?ª‘??‘¾÷‘¾ð‘?§ƒ?χ?î„ÿÿ‘?¸‘?σû©…ù?…ù?„?ð‘?©‘?î‘?¾‘«Ÿ‘æð‘û­…æÏƒ??ƒ?ÿ„?ÿ‘?œ‡?¾‘?ï‡?ÿ‘?©‡?ÿ‡?¾‘¾ü‘ûî‘?ÿƒ?¾‘­œŠñ­‘?©‘?ÿ‘?î‘??‘?ÿƒ?©‘?½‘?üÆ?ÿƒ?ïƒ?Ï‘ûæƒ?¾‘«œ‘æð‘û­‘?σ?©‡??‘ñ¸‡?¸‡¸¾…ù?ƒ?ÿƒ?ÿ‘?œ‡?ÿ‡?­‘æ­‡??‘?ý‡?ÿ‡?îƒ?ý‘û¾‘«ô‘?ûƒ?ý‘?σ?ü‘«œ‘æð‘û­‘?σ?üƒ??‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª‘÷ÿ‘??‡?¾‘¾ü‘?ï‡?©…ù?ƒ?ÿƒ?ÿ‘?σ?ü‡?õ‘ñ¸‘?ª‘?ð‡?ï‘?ÿ‘æî‘ñø‡­¾‡?¾‘¬ÿƒ?æ‘?σ?ü‘?­‘«œ‘?ª‘?σûü…ù?…ù?„?ð‘û݇?õ‘?ý‘¾ï‘ûî‘??‘?ð…ù?ƒ?ÿƒ?ÿ‡??‘??‘?¸‘?¸‡?ÿƒ?©‘«ø‘û¸ƒ?ï‘?χ?ÿ‡?¾‘¾ð‘?©‡?¸‘ûî‘?ÿƒ?¾‘«œ‘?©‘?¸‡?æ‡?­‘«¸ƒ?©‘?χ?©‘øÿ‡?¾‘?æƒ?ª‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª‘?ÿ‡?ü‘?ÿŠ?÷‡?œŠ?ï…暑??ƒ?ÿ„Ïÿƒ?ª‘?ø‡?æ‡?ÿ‘?õ‘¾õƒ?ý‘?χ?ÿ‡?îƒ?ï‘«ø‘û¸ƒ?ï‘?χ?ÿ‡?¾‘¾ð‘?©‡?¸‘ûî‘?ÿ‡?©‘?¾‡?¸‡?ïƒ??‡?üƒ?ý‘?ª‘ïÿ‘?­‘¾ù‘?©‘øÿ‘?î‘ñ­ƒñ¾‘÷ÿ‡?î‘æ­‘?ð‡?©‘øÿ‡?¾…ù?ƒ?ÿƒ?ÿ‘«ø‘û¸‡?ï‘?ÿƒ?¾‘?ï‘æý‘û¸‘¾­‘«üƒ?©ƒ??‘¾Ï‡?ü‘û­‘?œ‡?ÿ‡?­‘?ÿ‘??‡?­ƒ??‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñªƒ?ª‡?î‡?ÿƒ?©‘«ø‘û¸ƒ?ï‘?χ?ÿ‡?¾‘¾ð‘?©‡?¸‘ûî‡?ÿ‡?¾‘«ü‘û©‘ñ­‡?¸…ô?ƒ??ƒ?ÿ‘?ÿ‡?îƒ??‘?Ï‘?ÿ‡?­‘?­‡?¸‡??‡?ÿŠ?ø‘¾œ‘¾Ý‡?ñ‡?¾‘?ÿƒ?æ‚?ý‘?ª‡?ÿ‘¾ï‘¾ª‘?ü‘?ï‡?æ…暑??ƒ?ÿ…ïÿƒï?‘¾?‘?ª…ù?ƒ?ÿƒ?ÿ‡­?‘??‡?æƒ?¾‘?ª‡?ÿ‡?œ‡?¸ƒ?ï‡?ü‘??‘?¸Š?¸‘?ÿ‘û­ƒ?üƒ?ª‡??‘û¾‡?σ?¾‘«ª‘?œ‘?ªƒÿÿ‡?­‘?¾ˆ÷ÿ‘?ÿ‡?î‡?ð‡?î‘?ý‘û¸ƒ?õƒÝîƒ?ª‘?χ?ÿ‡?î‘?ï‡?ÿ‘?æ‘øÿ‡?¾…ïÿƒ??ƒ?ÿ‘?ÿ‘ûî‡?œ‘«¸‡?©‘?ÿƒ?ï‘?ô‘¾ý‘?­‘?ªƒ?ü‡?œŠ??‡?¾‡?ÿ‡?­‘øÿƒ?¾‘?ü‘¾ý‡?ø‡?ÿ‘¾î‘û¾ƒ?χ?ü‘ûî‘?¸‘?ªƒ?ü‘?χ?©‘øÿƒ?­…ù?ƒ?ÿƒ?ÿ‘?ü‡?ü‘«¸ƒ?©‘?­‘¾ï‘?ôƒ?©‘û?‡?¾‘øÿƒ?¾‘­œ‘澑û¸‘?ÿ‘?õ‘?œ‡??‘?ÿƒ?摾ݑ­œ‘?¸ƒ?ý‘?χ?ÿ‡?œ‡?¸ƒ?ï‡?¾‘øÿ‡?¾‡?ÿ‡?­‘æ­‡??‘?ýƒ?ü‡??‘û¾‡?ï‘ñ¾ƒûü…ïÿƒ??ƒ?ÿ„øÿƒ?¾‘¾Ý‘­œ‘?¸ƒ?ý‘«Ï‡?¸Šÿÿ‡?ïƒ?¾‘?ª‘?ÿ‡?¾‘¾©‡?¾‡?ÿ‡?­‘æ­‡??‘?ý‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒñ¾‘?ÿ‡?­‡?ÿ‡?îƒ?ü‘?ªƒ?ü‘?œ‘?ý‡?œ‡??‡?¾…ïÿƒ??ƒ?ÿ‘?ÿ‡?©Š?ýƒ?ü‡?­Š¸ýƒ?ü‘?ª‘÷ÿ‘æî‘?ÿƒ?¾‘?ø‘?ýЏð‡?ïƒ?¾‘¾?‘?ª‡?ÿ‘ûîƒ?ï‘û¸‘?ï‡?ýŠ?ýŠ?ï…æüƒ??ƒ?ÿ‘?ÿ‘æî‘?ðŠ?ÿ‘?ï‡?©‘øÿƒ?¾‘­œ‘澑û¸‘?ÿ‘?õ‘?œ‡??‘?ÿƒ?摾ݑ­œ‘?¸ƒ?ý‘?χ?ÿ‡?œ‡?¸ƒñï‡?ÿ‘¾æ‘¾ô‘?ÿ‡?¾‡?ÿ‡?­‘æ­‡??‘?ýƒ?ü‡?χ?ÿ‡?œ‡?¸ƒûï…ù?…ù?„?ð‘?÷‡?œ‘¾ï‘ûî‘«?‘¾ª‡¾œ…ù?ƒ?ÿƒ?ÿŠ??‘¾Ý‘¾©ƒ?ï‘?ª‡?ÿ‡?ï‡?­‘??‘?¸‘?ÿ‘?õŠ?÷‡?œ‘¾ï‘ûî‡?ÿ‡?­‘?ÿ‘??‡?­ƒ?ï‘?Ï‘øÿƒ?­‘?ü‡?ü‘«¸ƒ?©‘?­‘¾ï‘?ô‘?ÿƒ?ïƒ?ª‘û¾‘?ý‘¾õ‡?ü‘?ý…ïÿƒ??ƒ?ÿ‘?ÿ‘û­ƒ?ü‘?ª‡?ÿ‡?­‘?¸‘ñ½ƒ?¾ƒ?Ï‘û¾‘¾ô‘«ý‘û©‘澑û¾ƒ?ï‘?χ?©†?§„??‘?÷‡?œ‘¾ï‘ûî‘«?‘¾ª‡¾œ‡??‘?¾‡?¾‘û¾‘?œƒ?©…ù?ƒ?ÿƒ?ÿ‘?Ÿ‡?ÿ‡?­‘æ­‡??‘?ý‘÷ÿƒ?¾‘«ð‘¾Ï‘¾Ýƒ?¾‘?øƒ?ü‘?ª‡?ÿ‡?ï‡?­‘??‘?¸‘?ÿ‘?õŠ?÷‡?œ‘¾ï‘ûî†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª…ù?ƒ?ÿƒ?ÿŠ?Ï‘¾Ý‘¾©ƒ?¾‘?χ?©‘øÿƒ?¾‘??‘¾õ‡?ü‘?ý…ï©…ï?ƒï?‘«Ÿ‘æð‘û­…æÏƒ??ƒ?ÿ„?ÿŠ?÷‡?œ‘?ï‘øÿ‡?¾‘?ÿ‘æî‘?ð‘?©‡?¾‡?ÿŠ?ø‘¾œ‘¾Ý‘??ƒ?ü‘?ùƒ?ï‘?ªƒ?ü‘?ø‘?ýЏð‡?ï‡?¾Š?ÿ‘?ô‡?©‘?æ‡?ªƒ?¸‘«œ‘æðƒ?¾‘¾ü‘?ÿ‘ñª‡?¾Š?ÿ‘?ï‘?¸‡?©…ù?ƒ?ÿƒ?ÿ‘û¾‡?ï‘??ƒ?ü‘?χ?©‘øÿ‘Ïõ‡?©‡?¸ƒ?¾‘?Ï‘?ÿ‘æî‘?ð‘?©‡?¾†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒñª‡?ÿ‘¾æƒ?ü‘?ü‘?ÿ‡?¾‘?ðƒ?ª‘?ü‘?æ‡?ÿƒ?¸…ù?ƒ?ÿƒ?ÿ‘«?‡­?‡?¸‘?ÿ‡?ü‡?ÿŠ?ø‘¾œ‘¾Ýƒ§?„øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‘?ø‡?æŠÿÿ‡?ïƒ?¾ƒ?©ƒ?ðƒýî‡?ÿ‘?©‘?ÿ‘?ù‘§?ƒ?¾‡?î‡?ÿ…橃??ƒ?ÿ‘?ÿ‘«ªƒ?œ‘?χ?ÿ‡?œ‡?¸ƒûï…ù?…ù?ƒ?ÿƒ?ÿ‘¾?‘øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?¾ƒ?ïƒ?©ƒ?ðƒýî‘øÿƒ?¾‘?ï‡?÷ƒ?¾‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?Ï‘?ÿ‡?ü‘øÿƒ?æ‘?χ?©…ù?ƒ?ÿƒ?ÿƒ?ª‘û¾‡?ï‘??‡?ÿ‘?ï‘?©‡?­ƒûÏ…ù?…ù?ƒ?ÿƒ?ÿ‘¾?‘øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?¾ƒ?ï‘ûæ‘?ÿ‘«ªƒ?œ‘?χ?ÿ‡?œ‡?¸ƒñï‘?ÿ‘ñ¾‘¾æ‘?ðƒ?¸‘«Ï‡?¸Šÿÿ‡?ïƒ?¾‘ñø‘?­…ô?ƒ??ƒ?ÿ‘?ÿ‡?©‘?ý‘?ÿ‘?œ‘ñî‘?­‡?¾ƒÿÿ‡æ¯ƒ÷¸†?ÿ‡?îƒ?ü‘«ø‡?懸¾‡?ÿŠ?ø‘¾œ‘¾Ý‡?¾‡?ÿƒ?©‘ñ½‘?î‘?ÿƒ?¾‘?ü‘¾ý‡?ø‡?ÿ‘¾©‡?ñ‘澑û¾…æïƒ??ƒ?ÿ‘øÿ‡?î‡?ü‘?æ‡?ÿ‡?îƒ?ü‡­¾‘??‡?懸¾†?ÿ‡?î‡?¾‘­?‘ñ¾ƒûª‡­¾ƒ?¾‘?χ?©†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒûª„øÿ‡?¾‡?ÿ‡??‘ñæ‘?ï‡?ï‘?ÿƒ?æ‘ñ½‘?î‘?ÿƒ?¾‘?ü‘¾ý‡?ø‡?ÿ‘ûîƒ?ï‘?ý‡?©‡¾î‡??Š?ÿ‘øÿ‘Ïõ‡?©‡?¾‡?ø‡??‡?¾ƒ?ý‘?Ï‘?ÿ‘æî‘?ð‘?©‡?¾…ù?ƒ?ÿƒ?ÿ‘?ø‘?ý‡?©‡?ÿ‡?îƒ?ü‘«Ý‘æýƒ?¾ƒ?Ï‘?î‘?¦‡?ï†ÿÿ„ñ?‘?ÿ‡??‡??‘?¸‘¾ªŠ?üƒ?ü‡?¾‘÷ÿ‘ûî‡?ÿ‡?­‡?ÿ‡?îƒ?ü‘«Ý‘æýƒ?¾ƒ?Ï‘?î‘?¦‡?ï‘?ÿ‡?œ‘?¸ƒûü…ù?…ù?ƒ?ÿƒ?ÿ‘¾?‘øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?¾ƒ?ï‘ûæƒ?¾‘­œŠñ­‘?©ƒ?ª‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‘«Ï‡?¸Šÿÿ‡?ïƒ?¾‘?ª‘?ÿ‡?¾‘¾©‡?¾…ù?ƒ?ÿƒ?ÿ‘?ø‘?ýЏð‡?ïƒ?¾‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?σ?ª‘?œƒ?ý‘?ªƒ?ü‘?œ‘?ý‡?œ‡??‡?¾‘?ÿ‡?©Š?ýƒ?ü‡?­Š¸ýƒ?ü‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‘«ü‡?©…ù?ƒ?ÿƒ?ÿ‘û¸‘?ï‡?ýŠ?ýŠ?ïƒ?ü‘«œ‘æðƒ?¾‡?­‡?õ‘?ð‡?©ƒ?ü‘?Ï‘?ÿ‘æî‘?ð‘?©ƒû¾…ù?…ù?ƒ?ÿƒ?ÿ‘«?‡?æŠ?ÿ‡?œ‡?¸ƒ?¾‘ûæƒ?¾‘­œŠñ­‘?©‡?ÿ‘¾æ‘?ÿŠ?÷‡?œ‘?ï‡?ÿ‘?©‘?ÿ‘æî‘?ð‘?©ƒ?¾‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…廙??ƒ?ÿ‡?ÿ‘¾ï‘¾ª‘?üƒ?§‘?ª‘?ÿ‡?î‘?ðƒ?ï…ï§…Ï?ƒ?½‡ªÿ‘?¬‘æî‘?ð‘?©Æû¾ƒ?«…ù?ƒ?ÿƒ?ÿ‚?î‘øÿ‡?¾‘?ÿ‘¾æ‘ñª‘澇?¾ƒ?ü‘û¸‘¾Ï‡?ñ‘û¾ƒ?ï‘ûæƒ?¾‘­œŠñ­‘?©‘?ÿƒ?ïƒ?ª‡?î‡??‡?­‡?¾ƒ?ýƒ?χ?­‘?øƒ?ªƒ?ù…︃??ƒ?ÿ‘?ÿ‡?©‘?ý‘§?ƒ?¾ƒ?ª‡­¾‘??‡?æ‘«¸ƒ?©‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?Ï…ï©…ï?ƒï?‘??‡?ªƒ?ªÆ¬ðƒ?ªÆ¬î…ù?ƒ?ÿƒ?ÿ‘??‘¾Ý‘­œƒ?¾‘?œ‘ïÿ‡?¾‘?ü‘?õƒ?©‘¾?‡?ÿ‡?îƒ?ü‘û¾‡?¾‡?ÿ‘?©‘?ÿ‘æî‘?ð‘?©ƒ?¾‘«?‘?ú†?ý‘?ù‘ñª‘?©‘?÷‘?ÿ‘û­ƒ?ü‘¾?‘?©‡?î…æüƒ??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒñª‡?ÿŠ?ý‘¾Ý‘?÷ƒ?§‘?ªƒ?ü‘?ø‘?ýЏð‡?ï‡?¾‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?­‘?¾‡?ÿƒ?©‘¾ï‘?ýƒ?ïƒïùƒ?¸‡?¾…ù?ƒ?ÿƒ?ÿ‘«©ƒ?©‘?øƒ?ü‡?­‘?¾‡?ÿ‘?©‘?ÿ‡?­‘?ý‘¬ÿ‘ñ½‡?¸‘?æƒÿÿƒÏîƒ?©‘«?‡?æ‡?ÿ‡?î‘?ôƒ?§‡?æ‘ñ¸‡?¸‡?¾‡?ÿƒ?©‘¾ï‘?ýƒ?ï‡?î‡?ÿ‘?©‘?ÿ‡?­‘?ý‘¬ÿ‘ñ½‡?¸‘?æ‘?ÿ‘û­ƒ?ü‘柃ûχ­¾ƒû¾…ù?…ù?†­?„æ?„ñ?†??…ù?ƒ?ÿƒ?ÿ‘«?‘?ú†?ý‘?ù‘ñªƒïÿ†??‘«Ÿ‡?©‘ñî„?¾‘ñ¸ƒ?¾‡??†?ª‘?©„¾øƒû©‡??Æ?œ…ù?ƒ?ÿƒ?ÿ‘«?‘?ú†?ý‘?ù‘ñªƒïÿ‘?ô‡?ý‘«¸ƒ?©ƒ÷ýƒ?ø„÷ð„ñî‘?îƒ?î„Ïð‡?©‡?æ‘«?‘æý‡?­‡?ÿ‡­¾ƒ?ð‡?æ‡?ø„?ï‡?î‘?ðƒ?ï„æ?…æ?ƒ??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª„?ð‘û݇?õ‘?ý‘¾ï‘ûî‘??‘?ð„?ÿ‘æÏ‘û¸‘«?‘?ª…æüƒ??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª„?ð‘æî‘?ð‘?©‡ªÿ‘??ƒæï‡??‘û¾„ñï‘?îƒïÿ‘«?„ûõ‘æ­ƒ?¾‘?ü‡?œ‘¾ý‡¾ï…櫃??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª„?ð‘æî‘?ð‘?©ƒ?ÿƒ?Ý„?¯‡?¾„?ð‘?ô‡?©‘«?ƒ?õ„øð‘?î‘??‘?ð‡?ÿ‘?¾‡?æ‡?¸‡æû…ï½…ï?ƒ??ƒ?ÿƒ?ÿ†?ÿ‡?îƒ?ý‡?æ‘ñ¸‡?¸‡?¾‘øÿƒ?¾‘?ø‘?ýЏð‡?ïƒ?¾„?ð‘?©‘?î‘?¾‘«Ÿ‘æð‘û­ƒ?υ遼??ƒ?ÿƒ?ÿ‘«œ‘æð‘û­ƒ?σ?«‘?õ‡?¸ƒ?ÿƸœ‡??‘«ý‡?õ‘æ­‘?ÿ‘ñ¸‡?¾ƒ?½…ïõƒ??ƒ?ÿƒ?ÿ‡¾½‘?ïƒ?üƒ?«†??‡?û‘?ïƒûð‘??‡?÷„?©‘?©‘?î‘û¸†æõÆù§‘û?‘?¸‘?îƒû¾‘??„?ï‡?û‡?¾ƒ?ù‘«œ‘æð‘û­ƒ¾Ï…ù?ƒ?ÿƒ?ÿ‘?Ï‘?©‘?î‘?¾‘«Ÿ‘æð‘û­ƒ?σ?«„??‘ûî‘?ô‡?ýƸ?†?§„?î‡?­Æ?¾†?ï‡?ï‘û¸ƒ­õ‘?χ?û‡?¾…︃??ƒ?ÿ‡?ÿ‡?î‡?¾‘­ü‘ñ¾ƒûª‡­¾ƒ?¾‘?ð‘?©‘?î‘?¾‘«Ÿ‘æð‘û­ƒ?Ï‘?Ï‘?©‘?î‘?¾‘«Ÿ‘æð‘û­…æÏ„Ï?‡?ð‡?ü‘ñ½ƒ?¾‘?χ?ÿ‘?ý‡?¸‡?¾‘øÿƒ?­‘«œ‘æð‘û­‘?Ï‘?ÿƒ?©‘?ý‡?¸‘ûî‘?ÿ‡?õ‘?©‡?ÿ‘ñ­‡?¾ƒ?ý‘?χ?ÿ‡?­‘æ­‡??‘?ý‘Ïÿ‘?©‡?î‘?ý‡?œƒû¾ˆ÷ÿ‡?¨‡?÷ˆ¨¨‘÷ÿ‘?õ‡?ü‡?ÿ‡?­‡?ÿƒ?©‘«Ý‘æý‡?­‡?ÿ‘ñ­‘?¸ƒû¾„øÿ‡?¾‘?ÿ‡?î‘?ð‡?ï‡?ÿ‘ñ­‘?¸‡?¾‡?ÿ‘ûî‹«ï…阮??‡­¾…æï†ÿ?„ñ?…ù?‘«?‘?©…ù?…ù?
Exit code:  3
Paquete eliminar aplicaciones de metro
Publicado: 30 de julio de 2019 - 17:52
por Mathieu
Acabo de notar que en la configuración original había dos líneas de ##
old_removed.extend(removed)
    WAPT.write_param(control.package,old_removed)
Al eliminar el ##, el paquete se instala con un mensaje al final
NoneTraceback (most recent call last):
  File "c:\windows\temp\wapthz_wv2\setup.py", line 96, in install
  File "C:\Program Files (x86)\wapt\lib\json\__init__.py", line 339, in loads
    return _default_decoder.decode(s)
  File "C:\Program Files (x86)\wapt\lib\json\decoder.py", line 364, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
TypeError: expected string or buffer
Publicado: 18 de septiembre de 2019 - 16:45
por raselinary
Hola, recibí el siguiente mensaje y ¡no se ha desinstalado nada! Iniciando el proceso de descompresión... Intentando eliminar Microsoft.BingFinance Ninguno Intentando eliminar Microsoft.BingNews Ninguno Intentando eliminar Microsoft.BingSports Ninguno Intentando eliminar Microsoft.BingWeather Ninguno Intentando eliminar Microsoft.Getstarted Ninguno Intentando eliminar Microsoft.XboxApp Ninguno Intentando eliminar Microsoft.ZuneMusic Ninguno Intentando eliminar Microsoft.ZuneVideo Ninguno Intentando eliminar Microsoft.MinecraftUWP Ninguno Intentando eliminar Microsoft.BingFoodAndDrink Ninguno Intentando eliminar Microsoft.BingTravel Ninguno Intentando eliminar Microsoft.BingHealthAndFitness Ninguno Intentando eliminar Microsoft.WindowsReadingList Ninguno Intentando eliminar Flipboard.Flipboard Ninguno Intentando eliminar ShazamEntertainmentLtd.Shazam Ninguno Intentando eliminar king.com.CandyCrushSaga Ninguno Intentando eliminar king.com.CandyCrushSodaSaga Ninguno Intentando eliminar king.com.* Ninguno Intentando eliminar ClearChannelRadioDigital.iHeartRadio Ninguno Intentando eliminar 4DF9E0F8.Netflix Ninguno Intentando eliminar 6Wunderkinder.Wunderlist Ninguno Intentando eliminar Drawboard.DrawboardPDF Ninguno Intentando eliminar 2FE3CB00.PicsArt-PhotoStudio Ninguno Intentando eliminar D52A8D61.FarmVille2CountryEscape Ninguno Intentando eliminar TuneIn.TuneInRadio Ninguno Intentando eliminar TheNewYorkTimes.NYTCrossword Ninguno Intentando eliminar king.com.CandyCrushSag Ninguno Intentando eliminar king.com.CandyCrushSodaSaga Ninguno Intentando eliminar 828B5831.HiddenCityMysteryofShadow Ninguno Intentando eliminar Microsoft.Advertising.Xaml Ninguno Eliminado previamente por wapt: Aplicaciones metro restantes : "1527c705-839a-4832-9118-54d4Bd6a0c89", # (10.0.17763.1)", "7EE7776C.LinkedInforWindows", # (2.0.1.0)", "AppUp.IntelGraphicsControlPanel", # (3.1.0.0)", "AppUp.IntelOptaneMemoryandStorageManagement", # (17.0.1011.0)", "CyberLinkCorp.th.Power2GoforLenovo", #(8.0.8621.0)", "CyberLinkCorp.th.PowerDVDforLenovo", #(14.1.8627.0)", "E046963F.LenovoCompanion", #(4.26.43.0)", "E2A4F912-2574-4A75-9BB0-0D023378592B", # (10.0.17763.1)", "F46D4000-FD22-4DB4-AC8E-4E1DDDE828FE", # (10.0.17763.1)", "InputApp", # (1000.17763.1.0)", "Microsoft.AAD.BrokerPlugin", # (1000.17763.1.0)", "Microsoft.AccountsControl", # (10.0.17763.1)", "Microsoft.Advertising.Xaml", # (10.1804.2.0)", "Microsoft.Advertising.Xaml", # (10.1804.2.0)", "Microsoft.AsyncTextService", # (10.0.17763.1)", "Microsoft.BingWeather", # (4.25.12127.0)", "Microsoft.BioEnrollment", # (10.0.17763.1)", "Microsoft.CredDialogHost", # (10.0.17763.1)", "Microsoft.DesktopAppInstaller", # (1.0.22011.0)", "Microsoft.ECApp", # (10.0.17763.1)", "Microsoft.GetHelp", # (10.1706.10441.0)", "Microsoft.Getstarted", # (6.13.11581.0)", "Microsoft.HEIFImageExtension", # (1.0.11792.0)", "Microsoft.HEVCVideoExtension", # (1.0.12203.0)", "Microsoft.LockApp", # (10.0.17763.1)", "Microsoft.MPEG2VideoExtension", # (1.0.6.0)", "Microsoft.MSPaint", # (4.1807.12027.0)", "Microsoft.Messaging", # (3.43.27001.0)", "Microsoft.Microsoft3DViewer", # (4.1808.15012.0)", "Microsoft.MicrosoftEdge", # (44.17763.1.0)", "Microsoft.MicrosoftEdgeDevToolsClient", # (1000.17763.348.0)", "Microsoft.MicrosoftOfficeHub", # (17.8918.5926.0)", "Microsoft.MicrosoftSolitaireCollection", #(4.1.5252.0)", "Microsoft.MicrosoftStickyNotes", # (2.0.13.0)", "Microsoft.MixedReality.Portal", # (2000.18081.1242.0)", "Microsoft.NET.Native.Framework.1.6", # (1.6.24903.0)", "Microsoft.NET.Native.Framework.1.6", # (1.6.24903.0)", "Microsoft.NET.Native.Framework.1.7", # (1.7.25531.0)", "Microsoft.NET.Native.Framework.1.7", # (1.7.25531.0)", "Microsoft.NET.Native.Runtime.1.6", # (1.6.24903.0)", "Microsoft.NET.Native.Runtime.1.6", # (1.6.24903.0)", "Microsoft.NET.Native.Runtime.1.7", # (1.7.25531.0)", "Microsoft.NET.Native.Runtime.1.7", # (1.7.25531.0)", "Microsoft.Office.Desktop", # (16040.10730.20103.0)", "Microsoft.Office.OneNote", # (16001.10228.20003.0)", "Microsoft.OneConnect", # (5.1807.1991.0)", "Microsoft.PPIProjection", # (10.0.17763.1)", "Microsoft.People", # (10.1805.1361.0)", "Microsoft.Print3D", # (3.0.1521.0)", "Microsoft.ScreenSketch", # (10.1806.2112.0)", "Microsoft.Services.Store.Engagement", # (10.0.18101.0)", "Microsoft.Services.Store.Engagement", # (10.0.18101.0)", "Microsoft.SkypeApp", # (14.26.95.0)", "Microsoft.StorePurchaseApp", # (11805.1001.8.0)", "Microsoft.VCLibs.110.00.UWPDesktop", # (11.0.61135.0)", "Microsoft.VCLibs.110.00.UWPDesktop", # (11.0.61135.0)", "Microsoft.VCLibs.140.00", # (14.0.26706.0)", "Microsoft.VCLibs.140.00", # (14.0.26706.0)", "Microsoft.VCLibs.140.00.UWPDesktop", # (14.0.26905.0)", "Microsoft.VP9VideoExtensions", # (1.0.12342.0)", "Microsoft.Wallet", # (2.2.18179.0)", "Microsoft.WebMediaExtensions", # (1.0.12341.0)", "Microsoft.WebpImageExtension", # (1.0.11551.0)", "Microsoft.Win32WebViewHost", #(10.0.17763.1)", "Microsoft.Windows.Apprep.ChxApp", # (1000.17763.1.0)", "Microsoft.Windows.AssignedAccessLockApp", # (1000.17763.1.0)", "Microsoft.Windows.CapturePicker", # (10.0.17763.1)", "Microsoft.Windows.CloudExperienceHost", # (10.0.17763.1)", "Microsoft.Windows.ContentDeliveryManager", # (10.0.17763.1)", "Microsoft.Windows.Cortana", # (1.11.5.17763)", "Microsoft.Windows.NarratorQuickStart", # (10.0.17763.1)", "Microsoft.Windows.OOBENetworkCaptivePortal", # (10.0.17763.1)", "Microsoft.Windows.OOBENetworkConnectionFlow", # (10.0.17763.1)", "Microsoft.Windows.ParentalControls", # (1000.17763.1.0)", "Microsoft.Windows.PeopleExperienceHost", # (10.0.17763.1)", "Microsoft.Windows.Photos", # (2018.18051.21218.0)", "Microsoft.Windows.PinningConfirmationDialog", # (1000.17763.1.0)", "Microsoft.Windows.SecHealthUI", # (10.0.17763.1)", "Microsoft.Windows.SecureAssessmentBrowser", # (10.0.17763.1)", "Microsoft.Windows.ShellExperienceHost", # (10.0.17763.1)", "Microsoft.Windows.XGpuEjectDialog", # (10.0.17763.1)", "Microsoft.WindowsAlarms", # (10.1805.1361.0)", "Microsoft.WindowsCalculator", # (10.1805.1201.0)", "Microsoft.WindowsCamera", # (2018.425.120.0)", "Microsoft.WindowsFeedbackHub", # (1.1805.2331.0)", "Microsoft.WindowsMaps", # (5.1805.1431.0)", "Microsoft.WindowsSoundRecorder", # (10.1805.1941.0)", "Microsoft.WindowsStore", # (11805.1001.49.0)", "Microsoft.Xbox.TCUI", # (1.11.28003.0)", "Microsoft.XboxApp", # (41.41.18001.0)", "Microsoft.XboxGameCallableUI", # (1000.17763.1.0)", "Microsoft.XboxGameOverlay", # (1.32.17005.0)", "Microsoft.XboxGamingOverlay", # (2.20.22001.0)", "Microsoft.XboxIdentityProvider", # (12.44.20001.0)", "Microsoft.XboxSpeechToTextOverlay", # (1.17.29001.0)", "Microsoft.YourPhone", # (0.0.12084.0)", "Microsoft.ZuneMusic", # (10.18052.20211.0)", "Microsoft.ZuneVideo", # (10.18052.20211.0)", "RealtekSemiconductorCorp.RealtekAudioControl", # (1.2.148.0)", "Windows.CBSPreview", # (10.0.17763.1)", "Windows.PrintDialog", # (6.2.1.0)", "c5e2524a-ea46-4f67-841f-6a9465d9d515", # (10.0.17763.1)", "microsoft.windowscommunicationsapps", # (17.9330.21365.0)", "windows.immersivecontrolpanel", #(10.0.2.1000)",
Publicado: 25 de septiembre de 2019 - 11:29
por Mathieu
Sigo recibiendo un error en el paquete; tengo más de 100 estaciones de trabajo que muestran un error
Sigo recibiendo el mismo mensaje:
NoneTrying to remove Microsoft.MicrosoftOfficeHub
NoneTrying to remove Microsoft.MicrosoftSolitaireCollection
NoneTrying to remove Microsoft.OneConnect
NoneTrying to remove Microsoft.People
NoneTrying to remove Microsoft.WindowsAlarms
NoneTrying to remove Microsoft.WindowsMaps
NoneTrying to remove Microsoft.WindowsPhone
NoneTrying to remove Microsoft.WindowsSoundRecorder
NoneTrying to remove microsoft.windowscommunicationsapps
NoneTrying to remove Microsoft.MixedReality.PortalMicrosoft.BingFoodAndDrink
  File "c:\windows\temp\waptdzylcw\setup.py", line 98, in install
¿Tienes una solución?
Publicado: 25 de septiembre de 2019 - 15:08
por Gaetan
¿funciona el script ejecutándose manualmente en una de las máquinas que experimentan el error?
Publicado: 25 de septiembre de 2019 - 16:30
por Mathieu
En mi máquina virtual, el paquete ya no muestra ningún error, a pesar de que no he realizado ningún cambio.
Sin embargo, en otra máquina, al reiniciar la instalación, sigue mostrando un error.
