2020-04-27 14:24:34,670 DEBUG Default encoding : ascii
2020-04-27 14:24:34,670 DEBUG Setting encoding for stdout and stderr to UTF-8
2020-04-27 14:24:34,671 DEBUG Python path ['/opt/wapt', '/opt/wapt', '/opt/wapt/lib/python2.7', '/opt/wapt/lib/python2.7/plat-x86_64-linux-gnu', '/opt/wapt/lib/python2.7/lib-tk', '/opt/wapt/lib/python2.7/lib-old', '/opt/wapt/lib/python2.7/lib-dynload', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu', '/usr/lib/python2.7/lib-tk', '/opt/wapt/lib/python2.7/site-packages']
2020-04-27 14:24:34,671 INFO Using local waptservice configuration /opt/wapt/wapt-get.ini
2020-04-27 14:24:34,671 DEBUG Config file: /opt/wapt/wapt-get.ini
Using config file: /opt/wapt/wapt-get.ini
2020-04-27 14:24:34,676 DEBUG Thread 140231084709632 is connecting to wapt db
2020-04-27 14:24:34,704 DEBUG Using host certificate /opt/wapt/private/44454C4C-5A00-1058-8051-C4C04F42344A.pem for repo global auth
2020-04-27 14:24:34,718 DEBUG Thread 140231084709632 is connecting to wapt db
2020-04-27 14:24:34,719 DEBUG DB Start transaction
2020-04-27 14:24:34,719 DEBUG DB commit
2020-04-27 14:24:34,748 DEBUG Using host certificate /opt/wapt/private/44454C4C-5A00-1058-8051-C4C04F42344A.pem for repo wapt auth
2020-04-27 14:24:34,761 INFO Main repository: https://waptserv.there.lyc50.ac-caen.fr/wapt
2020-04-27 14:24:34,803 DEBUG Using host certificate /opt/wapt/private/44454C4C-5A00-1058-8051-C4C04F42344A.pem for repo wapt-host auth
2020-04-27 14:24:34,816 INFO User Groups:[]
2020-04-27 14:24:34,816 DEBUG WAPT base directory : /opt/wapt
2020-04-27 14:24:34,816 DEBUG Package cache dir : /opt/wapt/cache
2020-04-27 14:24:34,816 DEBUG WAPT DB Structure version;: 20190606
Registering host against server: https://waptserv.there.lyc50.ac-caen.fr/
2020-04-27 14:24:34,817 DEBUG DB Start transaction
2020-04-27 14:24:34,817 DEBUG DB commit
2020-04-27 14:24:34,826 DEBUG DB Start transaction
2020-04-27 14:24:34,826 DEBUG DB commit
2020-04-27 14:24:34,828 DEBUG DB Start transaction
2020-04-27 14:24:34,828 DEBUG DB commit
2020-04-27 14:24:35,948 DEBUG DB Start transaction
2020-04-27 14:24:35,949 DEBUG DB commit
2020-04-27 14:24:35,958 DEBUG Stores cert chain check in cache
FATAL ERROR : IndexError: list index out of range
File "/opt/wapt//wapt-get.py", line 1431, in <module>
main()
File "/opt/wapt//wapt-get.py", line 1213, in main
description=(" ".join(args[1:])).decode(sys.getfilesystemencoding()),
File "/opt/wapt/common.py", line 5477, in register_computer
inv = self._get_host_status_data(old_hashes, new_hashes, force=True, include_dmi=True, include_wmi=True)
File "/opt/wapt/common.py", line 5770, in _get_host_status_data
_add_data_if_updated(inv,'installed_softwares',setuphelpers.installed_softwares(''),old_hashes,new_hashes)
File "/opt/wapt/setuphelpers_linux.py", line 95, in installed_softwares
pkg_dict={'key':'','name':pkg.name,'version':str(pkg.installed).split('=',1)[1],'install_date':install_date,'install_location':'','uninstall_string':'','publisher':pkg.versions[0].homepage,'system_component':''}
