[RESUELTO] Paquete para habilitar Touch ID con sudo en macOS
Publicado: 28 de noviembre de 2024 - 14:09
Aquí está el paquete que hice para poder validar solicitudes de sudo con Touch ID en macOS.
Basé mi trabajo en este artículo: https://www.macg.co/macos/2023/08/macos ... -id-138763
import re
template_file = r'/etc/pam.d/sudo_local.template'
target_file = r'/etc/pam.d/sudo_local'
enabled_pattern = r'^auth\ *sufficient\ *pam\_tid\.so$'
disabled_pattern = r'^#auth\ *sufficient\ *pam\_tid\.so$'
def is_sudo_tid_enabled():
if not isfile(target_file):
error(r'File %s does not exists !' % target_file)
with open(target_file) as f:
for line in f:
if re.match(enabled_pattern, line):
return True
elif re.match(disabled_pattern, line):
return False
return "NOTMATCHING"
def enable_sudo_tid():
file_to_rewrite = []
for line in f:
file_to_rewrite.append(line[1:])
file_to_rewrite.append(line)
with open(target_file, r'w') as f:
f.writelines(file_to_rewrite)
def disable_sudo_tid():
for line in f:
file_to_rewrite.append(r'#' + line)
filecopyto(template_file, target_file)
# Check if already enabled
check = is_sudo_tid_enabled()
if check == r'NOTMATCHING':
error(r'Error matching pattern in %s file' % target_file)
if check:
print(r'TouchID support for sudo is already enabled.')
print(r'Enabling TouchID support for sudo...')
enable_sudo_tid()
print(r'Disabling TouchID support for sudo...')
disable_sudo_tid()
