[RESUELTO] Problema desde la actualización 2.6.0.16881
Publicado: 4 de febrero de 2025 - 9:06 a. m.
Hola a todos,
Desde esta mañana he notado una actividad anormal de la CPU en mis máquinas Linux (ubuntu/debian).
Acabo de notar que instalaron la última actualización de WAPT 2.6.0.16881 durante la noche, lo que parece estar afectando el funcionamiento del agente.
Adjunto capturas de pantalla del uso antes y después de detener el servicio Wapt; la diferencia es notable. También incluyo una captura de pantalla del estado en la consola.
Cuando intento una actualización wapt-get en las máquinas, este es el resultado:
Gracias por tu ayuda, mi servidor está empezando a sobrecargarse
Tomás
Using config file: /opt/wapt/wapt-get.ini
Nothing to upgrade
2025-02-04 08:58:46,341 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:49,342 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:51,664 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:54,749 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:58:57,502 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:01,060 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:03,257 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:05,931 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:08,402 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:11,145 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:13,385 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
2025-02-04 08:59:15,909 WARNING Host on the server is not known or not known under this computer name (known as None). Trying to register the computer...
Tomás
