Página 1 de 1
[RESUELTO] Error al instalar el paquete tis-microsoft-teams-uwp
Publicado: 27 de enero de 2026 - 17:07
por erems
Algunas computadoras están experimentando un error al instalar el último paquete tis-microsoft-teams-uwp 25332.1210.4188.1171-69
El error parece muy similar al de este hilo: viewtopic.php?t=3804
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1260, in run_powershell
    result = run(cmd,
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2263, in run
waptutils.CalledProcessErrorOutput: Command '"C:\\WINDOWS\\system32\\WindowsPowerShell\\v1.0\\powershell.exe" -NoLogo -NoProfile -NonInteractive -ExecutionPolicy Unrestricted -OutputFormat text -EncodedCommand "JABQAHIAbwBnAHIAZQBzAHMAUAByAGUAZgBlAHIAZQBuAGMAZQAgAD0AIAAiAFMAaQBsAGUAbgB0AGwAeQBDAG8AbgB0AGkAbgB1AGUAIgAKAEEAZABkAC0AQQBwAHAAeABQAHIAbwB2AGkAcwBpAG8AbgBlAGQAUABhAGMAawBhAGcAZQAgAC0ATwBuAGwAaQBuAGUAIAAtAFAAYQBjAGsAYQBnAGUAUABhAHQAaAAgACIATQBTAFQAZQBhAG0AcwAtAHgANgA0AC4AbQBzAGkAeAAiACAALQBTAGsAaQBwAEwAaQBjAGUAbgBzAGUAIAAgAHwAIABDAG8AbgB2AGUAcgB0AFQAbwAtAEoAcwBvAG4AIAA=" ' returned non-zero exit status 1.
Output:#< CLIXML
<Objs Version="1.1.0.1" xmlns="http://schemas.microsoft.com/powershell/2004/04"><S S="Error">Add-AppxProvisionedPackage : Échec de Add-AppxProvisionedPackage. Code d'erreur = 0xc1570118_x000D__x000A_</S><S S="Error">Au caractère Ligne:2 : 1_x000D__x000A_</S><S S="Error">+ Add-AppxProvisionedPackage -Online -PackagePath "MSTeams-x64.msix" -S ..._x000D__x000A_</S><S S="Error">+ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~_x000D__x000A_</S><S S="Error">    + CategoryInfo          : NotSpecified: (:) [Add-AppxProvisionedPackage], COMException_x000D__x000A_</S><S S="Error">    + FullyQualifiedErrorId : Microsoft.Dism.Commands.AddAppxProvisionedPackageCommand_x000D__x000A_</S><S S="Error"> _x000D__x000A_</S></Objs>
  File "C:\Program Files (x86)\wapt\common.py", line 4455, in install_wapt
  File "C:\temp\waptjrb38bp8\setup.py", line 27, in install
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1263, in run_powershell
    raise CalledProcessErrorOutput(e.returncode, cmd, e.output)
Output:#< CLIXML
Output:#< CLIXML
Gracias por su ayuda.
Atentamente.
Re: Error al instalar el paquete tis-microsoft-teams-uwp
Publicado: 28 de enero de 2026 - 15:53
por gadam
No puedo reproducir el problema en mi entorno de prueba. Dicho esto, el código de error 0xc1570118 parece indicar que una instalación o desinstalación anterior no se completó correctamente.
¿Puedes intentar eliminar el paquete de una estación con
wapt-get remove nomdupaquet
o si no hay ningún paquete WAPT Teams presente, use el comando de PowerShell
Remove-AppxProvisionedPackage -PackageName "MSTeams" -Online -AllUsers
¿Luego reinicia la instalación y nos mantienes informados?
Si esto funciona, agregaré la desinstalación antes de la instalación al paquete de la tienda.
Atentamente
Gwenaël
Publicado: 30 de enero de 2026 - 09:22
por erems
tras encontrarme con el error en unas sesenta máquinas, volví a la versión 25275.2601.4002.2815-68, que no presenta el mismo problema.
Vi que hay una nueva versión (26005.204.4249.1621) en PREPROD en la tienda; la probaré de nuevo y les informaré.
Gracias.
Publicado: 4 de febrero de 2026 - 9:22 a. m.
por erems
Por lo tanto, tengo el mismo error con la nueva versión del paquete (26005.204.4249.1621).
A pesar del error de instalación de WAPT, la aplicación se reinstaló correctamente y, según audit-appx, es la última versión. Además, funciona perfectamente en la PC.
Los comandos de desinstalación que sugirió no funcionan.
Si intento desinstalar el paquete 25275.2601.4002.2815-68 desde la consola, obtengo un error:
Entonces podría haber un problema con la información que se envía a WAPT para este paquete (?)
Publicado: 16 de febrero de 2026 - 10:26 a. m.
por erems
para dar seguimiento, el problema finalmente desapareció con la versión 26005.213.4315.4117-71 del paquete teams-uwp.
Por lo tanto, marco este caso como resuelto.
Saludos.
