Volevo darti un feedback su un problema (che potrebbe non essere tale)
Ho creato un pacchetto .msi e ricevo queste informazioni dalla console:
2023-03-28 11:28:16,883 CRITICAL Fatal error in install script: AttributeError: module '__waptsetup_sr4h0t49hx__' has no attribute 'install':
File "C:\wapt\common.py", line 4074, in install_wapt
AttributeError: module '__waptsetup_sr4h0t49hx__' has no attribute 'install'Se utilizzo la funzione WAPT: session-setup, non ricevo più alcun errore
Ecco lo script in questione:
print('installation de Impact9')
run(r'impact9.msi /qn')
#print('installation de la licence')
#install_msi_if_needed('impact9_lic.msi' )
#run_notfatal(r'impact9.msi /q /norestart',timeout=1200)Tuttavia, se invio l'installazione di questo pacchetto a una macchina remota, ottengo lo stesso errore:
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1907, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 710, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1282, in _run
Exception: Erreur lors de l'installation de ['iut-impact907(=9.0.0.0-5)']: erreurs dans les paquets [[PackageRequest(package='iut-impact907',version=(Version('9.0.0.0'), 5),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.22621.1413'),max_os_version=Version('10.0.22621.1413')), PackageEntry('iut-impact907','9.0.0.0-5' maturity='PROD'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5193, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4167, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4074, in install_wapt\n exitstatus = setup.install()\nAttributeError: module \'__waptsetup_m4ojr8c7v2__\' has no attribute \'install\'\n']]
self._run()
