[RISOLTO] Pacchetto WAPT dell-command-update-uwp
SeiyaGame
Registrazione: 25 maggio 2023 - 15:19
25 agosto 2023 - 17:09
Ho aggiornato questo pacchetto perché è disponibile una nuova versione, è la versione 5.0.0
Ho adattato il codice per tenere conto delle modifiche apportate sul sito web Dell e ho apportato anche alcune modifiche alle altre funzioni (forse non necessarie?)
Ecco il codice del file update_package.py:
from setupdevhelpers import *
import re
def update_package():
    # Declaring local variables
    result = False
    proxies = get_proxies()
    if not proxies:
    app_name = control.name
    url = "https://www.dell.com/support/kbdoc/en-us/000177325/dell-command-update"
    # Getting latest download link from official sources
    print("URL used is: %s" % url)
    for bs_search in bs_find_all(url, "a", "target", "_blank", proxies=proxies, timeout=10):  # , headers={"Accept-Language": "en,en-US"} not working
        url_title = (bs_search.string).replace(u'\xa0', u' ')
        if re.search("(?:Windows Universal|Universal Windows) (?:Application|Platform)", url_title):
            download_url = bs_search["href"]
            break
    # Getting latest version from official sources
    print("URL used is: %s" % download_url)
        download_url, "a", "class", "dellmetrics-driverdownloads", proxies=proxies, timeout=10
    ):  # , headers={"Accept-Language": "en,en-US;"} not working
        if "Télécharger" in bs_search.string:
            version = bs_search["href"].split("_")[-2]
            latest_bin = bs_search["href"].split("/")[-1]
            break
    print("Latest %s version is: %s" % (app_name, version))
    print("Download URL is: %s" % download_url)
    # Downloading latest binaries
    if not isfile(latest_bin):
        print("Binary is present: %s" % latest_bin)
        # Checking version from file
        version_from_file = get_version_from_binary(latest_bin)
        # if not version_from_file.startswith(version) and version_from_file != '':
        if Version(version_from_file) != Version(version) and version_from_file != "":
            print("Changing version to the version number of the binary (from: %s to: %s)" % (version, version_from_file))
            os.rename(latest_bin, bin_contains + version_from_file + ".EXE")
            version = version_from_file
            print("Binary file version corresponds to online version")
    if Version(version) > Version(control.get_software_version()):
        print("Software version updated (from: %s to: %s)" % (control.get_software_version(), Version(version)))
        result = True
        print("Software version up-to-date (%s)" % Version(version))
    control.version = "%s-%s" % (Version(version), control.version.split("-", 1)[-1])
    # control.set_software_version(version)
    # Deleting outdated binaries
    # Validating or not update-package-sources
    return result
Ecco il codice del file setup.py :
(Forse la modifica della funzione disinstallare E revisione contabile non è rilevante)
    bin_name = glob.glob("*Dell-Command-Update-Windows-Universal-Application*.EXE")[0]
    # Installing the software
    print("Installing: %s" % bin_name)
    install_exe_if_needed(
        bin_name,
        silentflags="/s /factoryinstall",
        name="Dell Command | Update for Windows Universal",
        min_version=control.get_software_version(),
        timeout=900,
    # Disabling telemetry
    registry_set(HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\General", "UserConsentDefault", 0)
    registry_set(HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\CFG", "ShowSetupPopup", 0)
    # Download updates (notify when ready)
    registry_set(
        HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\Schedule", "AutomationMode", "ScanDownloadNotify"
    registry_set(
        HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\Schedule", "ScheduleMode",
        "Auto"
    # Manual updates only
    # registry_set(
    #     HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\Schedule", "ScheduleMode",
    #     "ManualUpdates"
    # Disable notification
    # registry_set(
    #     HKEY_LOCAL_MACHINE, r"SOFTWARE\DELL\UpdateService\Clients\CommandUpdate\Preferences\Settings\Schedule", "DisableNotification", 1
    # Uninstalling the software
    print("Uninstalling: %s" % control.package)
    softs = installed_softwares('Dell Command | Update')
    for soft in softs:
        msiexec_command = ' '.join(uninstall_cmd(soft['key']))
        break
    run(msiexec_command)
    remove_appx("DellInc.DellCommandUpdate")
def audit():
    service_name = "DellClientManagementService"
    service_start_mode = get_service_start_mode(service_name)
    service_status = service_is_running(service_name)
    if service_start_mode in ["Disabled", "Manual"] and service_status:
        print("The Dell service is stopped and prevents the application from working properly.")
        return "ERROR"
        print("The Dell service is working properly.")
        return "OK"
Flavio.
Informazioni generali:
Server WAPT: Debian 11, versione 2.4.0.14143, Enterprise Edition
Macchina di amministrazione: Windows 11, versione WAPT 2.4.0.14143
jpele
Registrazione: 4 marzo 2019 - 12:01
Posizione: Nantes
13 settembre 2023 - 17:52
Grazie per il tuo feedback, ho modificato il codice di conseguenza.
Ho rielaborato il tuo audit per renderlo più affidabile e ho integrato la sezione del codice commentato.
Ecco il changelog:
now audit DellClientManagementService service
print that Dell Command Update UWP can only be installed on a Dell System
Per vostra informazione, il problema update_package è stato risolto due giorni fa nel repository: https://wapt.tranquil.it/wapt-testing
Se stai aspettando un pacchetto, sentiti libero di monitorare questo repository dalla tua console.
Sinceramente,
Jimmy
